6.0 oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 28 (permalink) Old 02-17-2011, 05:15 PM Thread Starter
6.0 oil leak
I have a small oil leak <occasional drip> on my '05 6.0. Seems to be coming from top rear of engine. Leaking off oil pan, front of bell housing, and starter. Appears to be more prevalent twd passenger side of engine. Any ideas?
Thanks
BIGDUX is offline
post #2 of 28 (permalink) Old 02-17-2011, 05:24 PM
DieselStroke's Avatar
Re: 6.0 oil leak
This might sound stupid, but are you sure it is oil and not coolant, soak it up in a paper towel and check the color of it, most likely it is coolant, in this case it would be your connector between oil cooler and EGR cooler, let us know, if it is indeed oil im not sure where it could be coming from.
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
DieselStroke is offline
post #3 of 28 (permalink) Old 02-17-2011, 06:48 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: 6.0 oil leak
Is it leaving a puddle under the truck?
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #4 of 28 (permalink) Old 02-18-2011, 01:04 PM
Re: 6.0 oil leak
possible turbo drain line?
04 f250 4" turbo back gauges diy coolant filter
ktmrydr686 is offline
post #5 of 28 (permalink) Old 02-18-2011, 02:57 PM
Re: 6.0 oil leak
Could be almost anything. Mine was the turbo drain. Test,verify,repair.
lenzhotrod is offline
post #6 of 28 (permalink) Old 02-19-2011, 03:19 AM
Re: 6.0 oil leak
mine leaks in the same spot. Just barely damp underneath with a droplet or 2.... coming off of starter. Might leave a spot the size of a quarter after a few days of sitting? I cleaned mine up really well and then re-diagnosed and mine is the glow plugs leaking. Evidently the glow plugs run thru an oil passage or something? I haven't fixed yet but that's what it looks like and I discussed it with someone on here a few months ago and that's what I found if its any help....
-Ryan
2004 CC SB 6.0L, T/S, red, FX4, XLT, Autometer GS Pyro and boost gauges. SCT Xcal2...tunes from Matt @ Gearhead Automotive
browtine is offline
post #7 of 28 (permalink) Old 02-19-2011, 03:23 AM
Re: 6.0 oil leak
i work at a dealer and haveseen many bedplates leaking sounds like what your talking about. clean the engine off real good with brake cleaner and check after driving it about 15-20 miles. good luck
truckshop is offline
post #8 of 28 (permalink) Old 02-23-2011, 11:49 PM Thread Starter
Re: 6.0 oil leak
Thanks guys. It is not leaving a puddle. If I wipe it off once a week, you hardly know it's leaking.
BIGDUX is offline
post #9 of 28 (permalink) Old 02-23-2011, 11:51 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: 6.0 oil leak
inspect oil psi sending unit
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #10 of 28 (permalink) Old 02-24-2011, 01:31 AM
Diesel Sled Head
zx800x's Avatar
Re: 6.0 oil leak
Check your hot side intercooler boot off the turbo. I have seen many of them seep just enough to leave a drip or two every now and then
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
Human Verification
