Another 6.0 won't start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-07-2011, 12:52 PM Thread Starter
Arrived at work and all was well, went to leave and just cranks and cranks. I read alot of the other won't start threads and tried some stuff but still nothing. I have a 2006 F250 and here is what I tried:
FICM = 48v key on and 48v cranking
Fuel pressure good.
The ICP to my understanding on an 06 is on the passanger valve cover? I did pull it out and put in a good running 6.0l truck, an 07 F250 and it started fine but after reading more, the truck will start without it plugged in. Not sure what else to check and ready to call a tow truck. I charged the batteries with a trickle charger and both are good and have a full charge. I do not have a good scan tool to see the fuel pressure and oil pressure. I just cracked the fuel line going into and comming out of the fuel filter and got lots of fuel.
Thanks in advance for any suggestions.
2006 F250 6.0
4" Turbo back exhaust
EGR Delete kit
SCT Tunner w/Extreme tunes from Defuser Performance Diesel
myronbilliot is offline
post #2 of 13 (permalink) Old 02-07-2011, 06:16 PM
i like to party
pizza pig's Avatar
Re: Another 6.0 won't start
wait, the truck starts with the ICP sensor unplugged?
I'd say the ICP sensor needs replacing
pizza pig is offline
post #3 of 13 (permalink) Old 02-07-2011, 09:08 PM
Busted Nuckles
He didn't say that. He said he pulled the ICP out and put it in another truck and that truck started fine. That means the ICP is OK.
Myron,
Did you try disconnecting the ICP and then attempt to start it?
bustednuckles is offline
post #4 of 13 (permalink) Old 02-07-2011, 09:32 PM
welcome to my world. 2 weeks going round and round, NO LUCK yet...
1. Fuel pressure is good
2. FICM checks out at 48v, even tried new one and reflash just incase
3. ICP psi over 1000psi
4. No fault codes
5. KOEO test ok
6. Crank sync ok
7. Injector click test ok
8. Late 04
Anyone help us??
marksman250 is offline
post #5 of 13 (permalink) Old 02-07-2011, 09:58 PM
Fuel pressure good.
What does your ipr read koeo and while cranking?
Ford Certified POWERSTROKE TECH....
F250-550 Everything....
bdavidsontexas is offline
post #6 of 13 (permalink) Old 02-07-2011, 11:06 PM
I had a similar problem....my truck died so i unplugged the ICP sensor and it started. Well I thought the ICP sensor was bad...nope. Replaced it a no change. Rplaced the main wiring harness cause it was in rough shape...no help there. Kept getting injector 2 high code. So i unplugged the injector number 2 and the truck fired right up as normal..with only 7 working injectors but still running fine. So i am having the injector replaced as we speak and head gaskets, studs, egr delete, and oild cooler to add a few...lol Good luck and I hope this helps.
Are you getting any injector codes?
Strokin304 is offline
post #7 of 13 (permalink) Old 02-07-2011, 11:12 PM
04 hotrod's Avatar
this could be your cam shaft position sensor or crank shaft position sensor. that would be my next step if i was doing it.
04 hotrod is offline
post #8 of 13 (permalink) Old 02-08-2011, 03:26 AM
has the hpop oil fitting been replaced to the upgraded one?
jzamluk is offline
post #9 of 13 (permalink) Old 02-08-2011, 02:32 PM
I would think it would start if the ICP is at 1000PSI. The only question i can come up with , is it cranking fast enough? Try this.
Attachment 19848
Attachment 19849
lenzhotrod is offline
post #10 of 13 (permalink) Old 02-08-2011, 04:05 PM Thread Starter
Myron,
Yes I did and no luck. One thing I noticed is the oil that seeped out when I pulled the ICP was black and old looking. The oil on the dipstick is clean looking. Could I have a blockage somewhere in the oil system? I think it has to be somewhare in the oil system, everything else check out fine. One more day of troubleshooting then it is off to the dealer via tow truck. Thanks for suggestions.
2006 F250 6.0
EGR Delete kit
Human Verification
