6.0 runs bad cold but good hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-13-2011, 01:54 PM Thread Starter
Question 6.0 runs bad cold but good hot
Hi, there all, I am needing some help with my first 6.0. Truck has very long crank time and runs like missing until engine gets up over 175 deg. was diag at empty your pocket local shop as having 2 bad injectors and egr cooler bad. Is this possible or should I be looking at something else.
earl641 is offline
post #2 of 13 (permalink) Old 01-13-2011, 02:39 PM
obsessive compulsive
capcalvin's Avatar
Re: 6.0 runs bad cold but good hot
Alot of people have had good luck with Rev-x additive to help with injetor stiction. REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil If you are using 15w40, you can try using a lighter oil such as rotella t5 10w30 or synthetic 5w40. As far as the EGR cooler, that will have to be deleted or replaced with the bullet proof model. Also, you should rebuild your oil cooler while you are in there. Blocked oil cooler is more than likely the couse of your EGR cooler failure. If you do the work yourself, your pocket will not be as empty.
'03 F350 6.0 DRW lariat 4x4
Autometer Gauges:
Pyro, boost, fuel pressure
Scangauge II
Bulletproof EGR cooler (blocked off)
Coolant filter
Delvac EC-1 ELC
Exhaust: MBRP 4" cat back with delete pipe
SCTx3 Tunes by Innovative and Gearhead
Swamps 58v FICM
High idle mod
SRW front wheel conversion
ARP head studs
capcalvin is offline
post #3 of 13 (permalink) Old 01-13-2011, 06:00 PM
Do Work!
boostfed's Avatar
Send a message via AIM to boostfed
A FICM update would be the first place I'd go with an issue like that, along with some Rev-X.
Ford Master Diesel Certified
6.7 6.4 6.0 certified
(919) 383-9300 OR Toll-Free # 1-866-757-6537
boostfed is offline
post #4 of 13 (permalink) Old 01-13-2011, 08:11 PM
yep, check ficm
engine oil and fuel additives
delete egr
Matt07 is offline
post #5 of 13 (permalink) Old 01-14-2011, 12:46 AM
Fixing Broken Stuff
toolmangary's Avatar
^^^ All good advise up there. Do you know what the codes were?? It will have some codes if it has bad injectors.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 13 (permalink) Old 01-14-2011, 02:41 AM
Do Work!
boostfed's Avatar
Not always. I've seen plenty of trucks run rough due to injector issues and not throw injector codes, however, sometimes a code does pop up when a concern in present.
boostfed is offline
post #7 of 13 (permalink) Old 01-14-2011, 03:35 AM
I had a 450 flatbed with 168k same symptoms. I changed the oil to rotella T6 with motorcraft filters (helped some), had the FICM reflashed (helped more), and then added some REV-X (Runs GREAT!!!)
LBZ_Duramax is offline
post #8 of 13 (permalink) Old 01-14-2011, 05:13 AM
5w40 moblie1 with 2 bottles of Rev-x is were i would start, the FICM is the next thing to check, as for the oil and egr coolers they are sources of problems on these engines but i dont think that is what your problem is
FTAJ is offline
post #9 of 13 (permalink) Old 01-14-2011, 02:38 PM
Sponsor
dalpilot's Avatar
2 bottles of rev-x will take care of that just fine.
dalpilot is offline
post #10 of 13 (permalink) Old 01-14-2011, 03:21 PM
Stroker67's Avatar
I run valvoline premium blue 5w-40 synthetic. The 6.0 injectors really seem to like it. I would check the FICM voltage, either with a computer or with a voltmeter, anything under 46 and its crap. Just upgraded my FICM to a 58v model. Haven't tried any Rev-X but if they were willing to let me test a few bottles for them Tim , i would try it. Also another way to see if your cooler is blown is to park your truck on an incline nose down and pull the EGR valve and check for wetness.
Stroker67 is offline
Human Verification
