Rocker arm fulcrum ? - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 20 (permalink) Old 01-07-2011, 06:18 AM Thread Starter
PSN Do it yourselfer
Ryan81's Avatar
Re: Rocker arm fulcrum ?
It makes sense to me to (1) thread the rocker arm fulcrum bolts in by hand far as you can before the head raises up. Then torque your ARP head studs down, now you don't have to worry about the fulcrum plate turning to the right/clockwise while you are torquing the ARP head studs down, however that could be putting the fulcrum bolts in a bind or turning the fulcrum plate to the right/clockwise a bit. Then finish the 23ft/lb torques on your rocker arm fulcrum plates. (2) Or maybe just start your fulcrum bolts, snug down your ARP head studs so the head wont raise. Make your torques on the rocker arm fulcrum plate then go back and torque the ARP studs down to 210 ft/lb. (3) Another way I see it is to just snug the top five ARP head studs that don't interfere with the rocker arm fulcrum plates, then torque all the rocker arm fulcrum plates to the 23ft/lb spec. Now put on your five bottom head stud nuts and torque all of the ARP head studs to spec. I see three ways of doing this, one of them has to be right. Anybody have an idea on which way to go?
Ryan81 is offline
post #12 of 20 (permalink) Old 01-07-2011, 08:30 AM Thread Starter
Ryan81's Avatar
Worried about bending pushrods or valves!!!! Is it possible to bend something either way you do this?
Ryan81 is offline
post #13 of 20 (permalink) Old 01-08-2011, 12:33 AM
speedracer1000's Avatar
always torque the head down first before you assemble the valve train. then put your pushrods and rocker arms on and torque them down. wont hurt nothing, nothin will get bent. and you didnt touch the cam timing and the pushrods just didnt magically change length. so nothing can really be wrong. some valves will just open when you tightin the rockers down cuz obviously at some point there are always a few valves open, but it wont hurt nothing, just torque to spec. valve lash isnt adjustable so no need to worry about that. i always try to keep everything paired up though because once the parts (lifters to pushrods, pushrods to rockers, rockers to valves) wear a pattern on each other you dont wanna change that pattern.
04 f250 cc/sb 6.0 industrial injection stage 1 turbo, sct tuned, edge insight, arp studs, rcd black onyx hg's, egr delete, 4" turbo back duals, banks high ram, bd boost builder, 4:30's, 4" procomp lift, eagle alloys, bfg a/t's
speedracer1000 is offline
post #14 of 20 (permalink) Old 01-08-2011, 01:51 AM Thread Starter
Ryan81's Avatar
How are you going to put the rocker arm fulcrum on if the head studs are already torqued down? Five of the head studs go through the rocker arm fulcrum plate on a 6.0. Your must have a 7.3 speedracer1000.
Ryan81 is offline
post #15 of 20 (permalink) Old 01-08-2011, 02:19 AM
Word
Fasttimez's Avatar
I found this for you....hope it helps....Don't take my word for it, read Diesel Power Mags write up.....
Picture #1
Next up, a set of ARP head studs (PN 250-4202) were threaded into the block. Then, the supplied, multi-layer head gaskets (five layers) were installed with the stamped numbers facing up. We should also note that because this was an '04 engine (and built before July 19, 2004), the cylinder head dowels' outside diameters measured 18 mm. After that, the new, pre-assembled driver-side cylinder head (PN 3C3Z-6049-DA) was set on the block. Unlike the 7.3L, the 6.0L features just four bolts per cylinder and 10 bolts per bank-which is why installing ARP head studs is so critical on these engines.
Picture #2
It's important to note that, before the head studs get torqued, the rocker arms must first be fastened to 23 ft-lb. According to Jose Dega of Diesel Tech, tightening the head studs before the rocker arms can lead to a bent pushrod when the engine is started. Also worthy of mentioning, on '03 engines some of the clips that the rocker arms ride on were plastic and became notorious for breaking (this was not the case with our '04 engine).
Picture #3
Once all rocker arms were tightened, the head studs were torqued. ARP's Ultra-Torque assembly lubricant was used for this process. Ultra-Torque was designed to be a metal-free, consistent, and repeatable way to achieve the ideal torque preload on the first torque cycle.
Don't tell me what your gonna do, come back and tell me what you did !!!
Fasttimez is offline
post #16 of 20 (permalink) Old 01-08-2011, 02:26 AM
i never take the rockers off the box...
105vegas is offline
post #17 of 20 (permalink) Old 01-08-2011, 04:23 AM Thread Starter
Ryan81's Avatar
Thanks Fasttimez! I'm gonna go with that!
Ryan81 is offline
post #18 of 20 (permalink) Old 01-08-2011, 03:32 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
hmmm...
I use my Snap-On 7.2 drill driver to run the nuts down, than you can do the 5 hold em bolts toward the intake. ofcourse the rocker box was already torqued to the head. As long as you have the bolts on the fulcrums hand tight, torque the nuts down, than hit the platforms up, 28 ft lbs...
I wouldnt listen to any Diesel Power Mag...
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #19 of 20 (permalink) Old 01-09-2011, 07:51 AM Thread Starter
Ryan81's Avatar
Thanks for the heads up CTC DEEZUL!
Ryan81 is offline
post #20 of 20 (permalink) Old 01-11-2011, 05:01 AM Thread Starter
Ryan81's Avatar
I ended up putting all the nuts on the studs hand tight and the bolts for the rocker arm fulcrum plates hand tight as well. Torqued the rocker arm bolts down to spec. Then I went back and torqued the head studs to spec. Now I put in the top five 10mm head bolts and torqued them down to spec.
Ryan81 is offline
Human Verification
