'05 F250 6.0 codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-11-2010, 03:30 AM Thread Starter
'05 F250 6.0 codes
My 05 6.0 king ranch has been no trouble until now. Three times in the last month I've stopped at a stop sign or signal light and the truck won't make any attempt to pull away. It just idles. Makes no difference how much the
accelerator pedal is pushed, it's as if the pedal is disconnected. After a minute or two it gradually accelerates and after a little sluggishness is okay.
There is no check engine light, but there are codes: U1900, B1352(IGN key-in circuit failure,B1483(Brake pedal input circuit failure) ,and P18769 (description unknown) The local dealer will replace parts until they find the right one,which
would be too costly. Hoping someone recognizes this condition. (127,000 mi)
Thanks in advance, Fred. (314)374-4530 Also !! I've felt the anti-lock vibration
in the brake pedal just prior to each episode - even though dry pavement, routine stop.
fredwho is offline
post #2 of 5 (permalink) Old 12-11-2010, 07:31 AM
Banned
Smut's Avatar
Re: '05 F250 6.0 codes
My truck does this on occasion when i yank on something. I can usually move the gear selector up and down then to the gear i want and it'll work again. the previous owner of my truck replaced the whole pedal thing down there at one point. So thats all i got for you is the suggestion of it being the sensors in the pedal.
Smut is offline
post #3 of 5 (permalink) Old 12-14-2011, 04:27 AM
Heavily Fordified
I talked to Doug at GoGo about this today and he mentioned that if one of the 5v reference wires has been pinched or rubbed, during an egr delete install or something like that...it could cause this.
2005 F350 RC Cab/Chassis dually- egr delete
Mcfly89 is offline
post #4 of 5 (permalink) Old 12-14-2011, 04:18 PM
Also your pedal is disconnected. Fly by wire.
lenzhotrod is offline
post #5 of 5 (permalink) Old 12-15-2011, 01:14 AM
Fixing Broken Stuff
toolmangary's Avatar
It sounds like the ABS is going in to false activation, you need to hook up a scan tool and watch wheel speed and see which sensor is dropping out. IDK if that is causing the acc pedal problem, but if the acc pedal act up just after the ABS problem I'd fix the ABS and then see what happens.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
Human Verification
