?? How to drain the fuel/water seperator?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 12-09-2010, 02:36 PM Thread Starter
Sorry, SUV's AINT TRUCKS
Cowboy Cadillac's Avatar
I received a water in fuel light on my 05 f250 so like a good little boy I went to the ford book. After looking at the sparse instructions I found the horizonal mouted fuel filter, but for the life of me, I could not find the drain lever that is referenced in the book. Has anyone else had to drain the water seperator on a 6.0L? If so, what is the best way to do it?
I know I must be over looking something, but what??
Cowboy Cadillac is offline
post #2 of 8 (permalink) Old 12-09-2010, 02:37 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: ?? How to drain the fuel/water seperator??
theres a 6mm allen head screw on the back of your frame rail pump, unscrew it and let it all run out then reinstall the screw and turn ur key on and let it run for about 45 seconds, i would also open the upper fuel filter housing to let the air out of the lines
Fordfreak4life is offline
post #3 of 8 (permalink) Old 12-09-2010, 02:59 PM
40 lug nuts
Snake's Avatar
fordfreak covered it. As you're under the truck looking at the HFCM, there's a 6mm allen head bolt facing you. Pretty much in the lower center of the housing. It may have been replaced with a knurled knob (popular upgrade), but that's what you're looking for. Be prepared for a diesel bath (its going to go everywhere), open it up, and drain until you see diesel coming out.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #4 of 8 (permalink) Old 12-09-2010, 03:03 PM
I would first spray it down with some PB Blaster..... and have a second allen head bolt there.... it strips out pretty easily
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #5 of 8 (permalink) Old 12-09-2010, 07:50 PM
Before you do it, get the drain plug upgrade: Diesel Technician Society
HFCM Water Separator Drain Plug Upgrade
FTG-05 is offline
post #6 of 8 (permalink) Old 12-09-2010, 08:00 PM
tmars51's Avatar
I like the drain plug upgrade, but on the web site, it shows for only 03-06. why will this not work in the 07?
35 inch Hankooks with a level lift and F350 rear blocks, AFE stage 2 intake, Procomp dual steering stabilizer, HID headlights, Westin bull bar with Procomp lights, Dodge Cab Lights, Edge Evolution Programmer, coolant filter, Sinister EGR delete, smoked tail lights & 60 inch LED bar, straight piped, high idle mod, ZooDad mod
tmars51 is offline
post #7 of 8 (permalink) Old 12-09-2010, 08:02 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
X2 on the knurled upgraded plug mentioned, and the PITA that, that little plug is
Previous owner of my truck never drained the water (50k miles) and the brass plug liked to corode right to the cover on the hfcm as well. In my case we had to drill out the plug and replace it nce everything was cleaned up.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #8 of 8 (permalink) Old 12-09-2010, 11:01 PM
FTG-05 is offline
Human Verification
