Head studs without replacing gaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 11-05-2010, 11:07 PM Thread Starter
PSN Been daer dun it!
Cajunhunter67's Avatar
I have a 2004 6.0 with 158k miles. Runs great, no oil leaks, no issue with anything much. I have installed an SCT tuner, 4 inch exhaust, no cat or muff. I want to replace the HBs with studs. The gaskets are still good. Was thinking removing one bolt at a time and eplacing with a ARP stud in the correct torque sequence. Seems this is all that would need to be done. head gaskets leak due to stretched bolts, not gasket failure. Also installing EGR delete, new turbo boots, and O/H kit in the oil cooler. Has anyone done this with the head bolts with no issues. Would save alot of work, versus removing the heads! Holla back atta FORD brutha!
Cajunhunter67 is offline
post #2 of 14 (permalink) Old 11-05-2010, 11:31 PM
Stonepusher's Avatar
Re: Head studs without replacing gaskets?
from what I have heard it doesn't work, the reason the head gaskets fail is bc of the heads not being flat.
2005 F-250 2wd converted to 4wd.
12.0@110 Fuel Only
10.93@123 Juice
BTS 4r100, 225/100's, TSD sump, TSD fuel system, TSD tuned, Barder stage 3, and some other goodies.
THANKS TO TRUCK SOURCE DIESEL!
Stonepusher is offline
post #3 of 14 (permalink) Old 11-06-2010, 01:18 AM
chris@mpd's Avatar
it doesnt work, i tried it on my own truck with only 10,000 miles on it and they still didnt hold
chris@mpd is offline
post #4 of 14 (permalink) Old 11-06-2010, 01:22 AM
thats me
no,it wont work,and if your that far down in there you might as well pull em and get em decked
harley1rocker is offline
post #5 of 14 (permalink) Old 11-06-2010, 01:26 AM
Sponsor
04stroker's Avatar
There's guys that have had some sucess with it but in my opinion it's not the right way to do it and be done with it.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #6 of 14 (permalink) Old 11-06-2010, 01:34 AM
^^^^^This isn't Soul Train, so please don't ever say that again.
As for the studs, if your gonna do it, might as well do it right the first time.
2005 F-350 XL CC LB 4x4
Auto, SCT, Tunes from Eric, 03 Turbo, Exhaust, Coolant filter
2008 F-250 XLT CC SB 4x4
6.4 Auto, 6in Procomp lift, 37x12.50r20
Originally Posted by yogi7615 View Post
Unfortunately, there are too many animals wanting handouts and too many bleeders willing to give away other peoples money that it won't be easy to remove the stupid one.
willholl79 is offline
post #7 of 14 (permalink) Old 11-06-2010, 01:45 AM
SamW's Avatar
I would pull the heads... but that is just me. Make sure you have a machine shop check them out. Studs wont hold if the head is not flat.
2006 F250 CCSB
6.
SamW is offline
post #8 of 14 (permalink) Old 11-06-2010, 02:19 AM
07_powerstroke's Avatar
I did it that way but i had ford warranty do the gaskets they wouldnt actally put the studs in for me so i ended doing it right after so they had around 1000 miles on brand new gaskets. I did talk to the machanic and he said my heads were perfect actually he couldnt belive how good they were...I have sct on extreme race i drive the truck very hard i also pulled 12,000 lbs on a tow tune and i havent had any issues... But if i was in your situation i would def pull them!
07_powerstroke is offline
post #9 of 14 (permalink) Old 11-06-2010, 03:33 AM
it's an 02 05 08
turbodiesel_02's Avatar
if you want them to last pull the head machine it and stud it,then never worry about
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #10 of 14 (permalink) Old 11-06-2010, 03:44 AM
DieselStroke's Avatar
Also i would not do the ARP studs until the current HG's fail, right now you have the factory torque on the heads, purchase the Head Studs and just wait until you start to puke with confirmed bad HG's, then take it apart, put onyx gaskets on and install head studs.
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
DieselStroke is offline
Human Verification
