03 6.0L oil drain holes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-24-2010, 02:50 PM Thread Starter
does anybody have a diagram of these holes? Replacing injectors and need to know what holes to plug with towels? I have holes in the top and the bottom. Thanks, Craig
Critter62675 is offline
post #2 of 9 (permalink) Old 10-24-2010, 03:36 PM
Re: 03 6.0L oil drain holes?
What are you talking about? Pull valve cover, stand pipe, hpop rail, and injector. Lube O-rings on new injector and install. Torque to 26 ft. lbs, and put back together. Bump starter over several times until all is clear and then crank away. No plugging anything with towels here. Got a dremel tool? Use that wrench for changing bits for the hose on the hpop rail.
matty169 is offline
post #3 of 9 (permalink) Old 10-24-2010, 03:55 PM Thread Starter
checking because manual and internet say plug these holes so nothing falls in them and so you won't have to take off head. There is 2 holes one above the injector and one below the injector bracket. I just don't want to have to pull the head.
post #4 of 9 (permalink) Old 10-24-2010, 03:58 PM
it's an 02 05 08
turbodiesel_02's Avatar
just be very cautious espcially on the passanger side,the rags will get in the way in imo
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #5 of 9 (permalink) Old 10-24-2010, 03:59 PM Thread Starter
Thanks, but gladly I just have to change #6 and #8 on the drivers side.
post #6 of 9 (permalink) Old 10-24-2010, 05:03 PM
it's an 02 05 08
you lucked out,thats the easy side
post #7 of 9 (permalink) Old 10-24-2010, 05:09 PM Thread Starter
So does anybody know what the holes are below the injector bracket screw?
post #8 of 9 (permalink) Old 10-24-2010, 10:14 PM
it's an 02 05 08
i believe drains the injector holddown torx screw wont fall out of the hold down
post #9 of 9 (permalink) Old 10-25-2010, 03:27 PM Thread Starter
Does the oil go from the oil drain holes in the head to the oil pan?
Human Verification
