Turbo underboost code Po299 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-22-2010, 09:05 PM Thread Starter
Hey guys. My service engine soon light came on last Sunday, lastnight I went and got the code pulled and it came up PO299 Turbo/supercharger underboost. I am not noticing a difference in power and the gauge hasnt changed. I bought the truck from my girlfriends dad when he got his 2011 6.7L. He always drove the truck pretty aggressively also pushing the throttle as far as he could. I dont drive it like that at all. Im really nice to and just let it crawl up through the the gears and rpms and dont use the turbo all that much. Not like he did anyways. Im wondering if maybe my driving style has cause this. Is there a chance the turbo could be dirty, gummy, or plugged up in anyway since it doesnt see alot of hard use? Im new to the diesel world so please bare with me, I have done all the searching I could. I have also checked all hoses and tubes for loose connections? If I change my driving style is there anyway I might be able to clean the turbo out that way?
Thanks
Tom
tsedsell is offline
post #2 of 14 (permalink) Old 10-22-2010, 09:13 PM
DieselStroke's Avatar
Re: Turbo underboost code Po299
Are you referencing a separate boost gauge that you have or do you read boost off of the PCM through a Tuner? Could be that MAP sensor going bad, someone else chime in.
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
DieselStroke is offline
post #3 of 14 (permalink) Old 10-22-2010, 09:23 PM
diesel and nothing else
amarillo250's Avatar
Send a message via Yahoo to amarillo250
carbone build up on the vanes and something came loose. That was it in my case 3 years ago and a turbo later.
06 F250 CCSB, still working on it
Thanks to FCDP and all the guys on here for their help.
amarillo250 is offline
post #4 of 14 (permalink) Old 10-22-2010, 09:40 PM Thread Starter
Im reading it by the stock gauge. Its not acting any different or running bad at all. Just dont like seeing that light on.
tsedsell is offline
post #5 of 14 (permalink) Old 10-22-2010, 11:12 PM Thread Starter
Im not running any additives in my fuel, its not missing at any time, i rarely ever run it over 2500 rpms on take off or run much over 60mph.
tsedsell is offline
post #6 of 14 (permalink) Old 10-22-2010, 11:26 PM
Epd444's Avatar
I'm no 6 liter expert but we have a work van with a 6.0 in it. It threw the same code a month ago, I cleared it. Last week it threw the code again. Both times just like you- everything felt fine, this is on a van though so no boost gauge.
We brought it in the dealership the second time since its under warranty, they had to take the turbo out and they said it had rust? or somethin built up on it and needed to repair it.
Just your average 7.3
Epd444 is offline
post #7 of 14 (permalink) Old 10-22-2010, 11:35 PM
What kind of boost numbers are you showing? Cleaning the turbo should not be that bad, there is a manual on here on how to rebuild it.
Westin Bull Bar
Lights
post #8 of 14 (permalink) Old 10-23-2010, 12:39 AM Thread Starter
it gets to about 20-24 psi thats all its ever done since it got a new turbo on it 5 years ago. They reprogrammed the truck, it used to push about 32-36 psi on the old turbo.
tsedsell is offline
post #9 of 14 (permalink) Old 10-23-2010, 12:42 AM
what year is that truck and 32 to 36 is a lot for the 6leaker in stock set up.
post #10 of 14 (permalink) Old 10-23-2010, 02:27 PM Thread Starter
The truck is a 2005, yeah the ford garage told my girlfriends dad that 32-36 psi was to much for the 6.0s thats why they were reprogramming them. And ever since its done about 22-24 and never had any problems. The truck is not low on power or anything, if that light wasnt on you would have no idea that anything was different. Do you think it just needs to be cleaned?
tsedsell is offline
Human Verification
