4 inch vs 5 inch, turbo back vs cat back - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 10-09-2010, 09:09 PM Thread Starter
ggcustoms's Avatar
Just wondering some opinions on Aftermarket exhaust for my 6.0, I've read that 6.0's don't benefit much from the bigger down pipe? True? Also whats the benefit in eliminating the cat. converter? Also I've been looking at a Diamond Eye stainless system, Are they any good? I tow a two horse trailer once a week and Enclosed snow trailer for trips up north and out west(1000 miles+) and not a big fan of loud cab noise, So I was leaning toward a mufflered system. Any comments would be great, Thanks GG
If you didn't have your 6.0 what would you spend all your money on?????
ggcustoms is offline
post #2 of 20 (permalink) Old 10-09-2010, 09:11 PM
Re: 4 inch vs 5 inch, turbo back vs cat back
The cat is just restricting it. And I would do a turbo back.
02 f250
countryboyrob is offline
post #3 of 20 (permalink) Old 10-10-2010, 05:20 PM
mmmm...beer....
wetnsloppy4x's Avatar
A bigger downpipe will help keep EGTs a little lower. If your truck is stock, you won't notice much difference in power. The bigger exhaust starts helping (performance wise) once you put tunes on and upping the power in other ways.
IMO, go turbo back. Pipe size is entirely up to you. You won't gain any more power going to 5". The bigger pipe will make the exhaust tone a fair amount deeper though.
Scott
06' F-250 Harley Davidson CC SB
Lifted 6", 37" Nitto Mud Grapplers, intake, exhaust, gauges, tunes by Eric, GoGo Stage 1, Power Max, Strictly RR, Ported Uppipes, Swamps 58v FICM w/Atlas 80, 5r by Elite.
04' Excursion
Stock
99' F-250 EC SB
Stockish
wetnsloppy4x is offline
post #4 of 20 (permalink) Old 10-10-2010, 06:55 PM
06-sixoh's Avatar
If you have to smog your truck, you need to leave your CAT in. I live in cali, so I have to leave my CAT in, and do a CAT back exhaust. With a turn down under the cab, and a hollow CAT, the powerstroke can be roudy sometimes. I plan on leaving the CAT, running 4" CAT back with a muff. This will keep the noise to a minimal, and hopefully still keep the EGT's cool when towing and tuned.
2006 F250 CCSB FX4 Lariat
GlowShift Tinted gauges, Recon Clear Cab Lights, Diamond Eye Duals, SRL Files, 2.5" rize leveling kit, F350 Rear Blocks, PHP Tuned FICM, Retro Solution 6K HID's, DieselSite Coolant Filter...
2011 Oxford White SuperCrew EcoBoost FX2
06-sixoh is offline
post #5 of 20 (permalink) Old 10-10-2010, 09:36 PM
Powersmokesd's Avatar
I just did a 4 inch turbo back with the muff on my uncle's truck. He tows a trailer with it and he loves the sound. It sounds stock until about 2500rpm's then you can hear it.
A buddy of mine had a 5 inch turbo with no muff and an 8" tip and you could hear him coming from blocks away.
Hope this helps
Rollin' Black Smoke!
Powersmokesd is offline
post #6 of 20 (permalink) Old 10-10-2010, 10:58 PM
Wondering what if
123rday68's Avatar
I'd go with the turbo back system. If you need to have a cat on for inspections, there are aftermarket 4" and 5" diesel cats for @ $250-$300 for less restrictions. or as stated before, you could hollow out yours.
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #7 of 20 (permalink) Old 10-11-2010, 04:44 PM
Power Junky
Lubbockguy1979's Avatar
Or notice pretty close to the same egts as a 4" by removing the muffler and either ditching the cat or hollowing it out. The cost is a lot less. The 3.5 inch exhaust with out a muffler or a cat is sufficent for a stock stick truck in my opinion.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #8 of 20 (permalink) Old 10-11-2010, 04:49 PM
07strokerftw's Avatar
cat is bad... very restrictive, but if it's necessary for emissions inspections then leave it and do what they said (get a less restrictive one) diamond eye or MBRP have sweet turbo back 4" or 5" systems with mufflers included, you can turn the muffler in whichever direction you want for a little more noise or less noise, if you want little cab noise then go with the turbo back muffler system
2007 F250 ccsb Lariat
33" Nitto Terra Grapplers on stocks, SCT x3 with custom extreme tunes from IDP, Autometer gauges, zoodad air mod, "2003" turbo, carriage works billet grill layover, HID 6000k, headstuds/egr delete, 6.4 banjo fuel bolt upgrade, 4" turbo back to 7" single stack
07strokerftw is offline
post #9 of 20 (permalink) Old 10-12-2010, 02:30 AM
I have a 4" stainless turbo back Magnaflow with muffler. Very happy with it. I wanted a muffler so my 4 yr old daughter could still sleep in there when rolling. Works great
horsehauler is offline
post #10 of 20 (permalink) Old 10-12-2010, 07:41 PM
06-sixoh's Avatar
My boy loves the sound of the powerstroke. He falls asleep in my truck more often than my wife's quiet Acura. When we go through tunnels, he always tells me to "go loud".
OP, sounds like a muffler is what your wanting.
06-sixoh is offline
Human Verification
