2004 6.0L Coolant Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-02-2008, 02:07 AM Thread Starter
East County stroker's Avatar
Just got my truck back from dealer they replaced the EGR cooler and front cover gasket . I noticed today I still have coolant leaking by the right front tire need help with issue any help
East County stroker is offline
post #2 of 8 (permalink) Old 03-02-2008, 02:57 PM
Sponsor
airflo71's Avatar
Re: 2004 6.0L Coolant Leak
Keep your coolant level in the bottle a switch below the MIN mark that is in it. This should help and if it doesn't let me know. There are a few "other" ways to fix this but this should do it.
airflo71 is offline
post #3 of 8 (permalink) Old 03-02-2008, 10:06 PM Thread Starter
I will give this a try thanks for your help nobody else will
post #4 of 8 (permalink) Old 04-04-2008, 09:00 AM
iceman89m's Avatar
Take a good look at all of your radiator hose and heater hose clamps,The oem steel spring clamps are junk, I have had to replace 3 on mine with the stainless type clamps, the oem's had broke and antifreeze was seeping
iceman89m is offline
post #5 of 8 (permalink) Old 04-04-2008, 06:58 PM
HarleyEdition78412's Avatar
Can't you just take the truck back to the dealer and say look what you did/didn't fix?
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #6 of 8 (permalink) Old 04-06-2008, 10:11 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Ya take the truck back and find out what they did. Also if its coming from his right side it can be different things I had the same problem till I deleted it.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #7 of 8 (permalink) Old 04-06-2008, 10:37 AM
kingranch6.0's Avatar
head stds!!!
04 leaker
kingranch6.0 is offline
post #8 of 8 (permalink) Old 04-22-2008, 10:07 PM Thread Starter
I took truck back they said it was the oil cooler this time, but also I check the hose on the EGR cooler its now blue it was orange . Now I'm wondering if they did anything last time it was in or just said they fixed something ,all good now though .
2004 F 250 Fx4
4" MBRP Turbo Back No Kitty
Billet Grille
Zoodad Mod
Isspro Pyro & Boost
CCV Mod
2.5 Leveling kit
Human Verification
