2006 6.0L IPR - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-08-2010, 10:19 PM Thread Starter
Question 2006 6.0L IPR
In normal life, would a IPR(injection pressure regulator) activate when supply with 12VDC? I get a small spark on the pin but the coil don't pull the valve.
Thanks for input
wrench
metricwrench is offline
post #2 of 4 (permalink) Old 05-09-2010, 12:35 AM
Re: 2006 6.0L IPR
The valve closes with the application of 12V power. If you apply 12V power for more than 30 seconds (IIRC) you can burn out the electronics.
Mark
bismic1 is offline
post #3 of 4 (permalink) Old 05-09-2010, 03:12 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: 2006 6.0L IPR
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 4 (permalink) Old 05-10-2010, 02:13 AM Thread Starter
Re: 2006 6.0L IPR
Thankss wrench
Human Verification
