Bad stutter/shudder - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 28 (permalink) Old 05-11-2010, 02:24 AM
Re: Bad stutter/shudder
Mine does the same thing. I'm hoping its just the egr valve
Mustangl3 is offline
post #12 of 28 (permalink) Old 05-11-2010, 02:29 AM
Word
Fasttimez's Avatar
The shutter you feel is your injectors not getting enough oil pressure to operate properly due to clogging/coking ( commonly referred to as injector sticking)...the reason it's only present in OD is because the engine RPM has steadied out and between about 1,200 and 1,700 RPM in OD the load on the engine is so low that any heavy clogging in oil passages in injectors causes them to misfire or ( stick the spool valves ) by changing engine load you force more oil through the injector at a higher PSI....this problem is common on cold starts and gets better as the truck warms up due to the oil getting thinner and flows better when hot....if your truck is doing it all the time, hot or cold than an alternative to injector replacement is switching to a 5w40 oil and adding a product like REV-X....but remember these are not permanent fixes...there's no way to clean the injector properly without removing it....
Fasttimez is offline
post #13 of 28 (permalink) Old 05-11-2010, 02:21 PM Thread Starter
Breaks Stuff
machine's Avatar
That actually makes a lot of sense, as how the truck doesn't fire right up when I turn the key over, anymore. It cranks over a few times before it starts, and runs. So, basically, what you're saying, is I have to pull the injectors?
'04 6.0L
SCT X3 (Looney Tuned), Coolant Filter, Zoodad Mod, BB Mod, EGR Delete, CCV Reroute, 220 AMP Alternator, 4" Turbo-Back Exhaust w/ Cat Delete, 4" ProComp, 35" MudGrapplers, Shell (color-matched), Winch Mount/Brushgaurd, Warn 15k Winch, Taillight Gaurds, TV/DVD w/ Game Console Hookup
For Sale
machine is offline
post #14 of 28 (permalink) Old 05-11-2010, 02:54 PM
Word
Fasttimez's Avatar
The only way to fix this problem correctly is to either replace your injectors or pull them out, pull them apart, clean them and reassemble them ( But I wouldn't recommend pulling them apart unless you have experience at this ) Now a way to get some more life out of them is to switch to a 5w40 motor oil and add a lubricity additive like Rev-X or something...the thinner oil and the additive will counter act the deposit and coking buildup for awhile, but eventually you'll have to replace the injectors, but you can probably get about 50,000 miles of trouble free running, this will also give you some time to save for injectors....this was a poor design by Ford, the 7.3 injectors never had this problem despite being an oil operated injection system also...Ford scrapped this design starting with the 6.4....
post #15 of 28 (permalink) Old 05-11-2010, 03:46 PM Thread Starter
Breaks Stuff
machine's Avatar
Guess I'll get some Rev-X, as I've been running 5w-40 synthetic for quite some time.
'04 6.0L
For Sale
machine is offline
post #16 of 28 (permalink) Old 05-11-2010, 05:39 PM
Word
Fasttimez's Avatar
Rev-X has worked miracles in alot of peoples vehicles...it's def. worth the price you pay, I should know cause I run it in my truck....it took care of my injector problem, but for how long...who knows...3,000 miles and counting so far with no problems...
post #17 of 28 (permalink) Old 05-11-2010, 06:04 PM
Mpoage's Avatar
Did it cure your shuddering problem or just calm it down some
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #18 of 28 (permalink) Old 05-11-2010, 08:29 PM
Word
Fasttimez's Avatar
It totally cured my shuddering problem....but like I said, for how long is anybody's guess...I just added it this last oil change and after a couple minutes of running the problem was gone and hasn't come back...but i think the catch is you have to add this stuff to every oil change...which can add up pretty quick if you put alot of miles on your truck...I change my oil every 5,000 miles, I've put 3,000 on it since oil change + rev-X and no problems at all...
post #19 of 28 (permalink) Old 05-12-2010, 01:41 AM
USMCpoolee's Avatar
can you run rev x in automatics
USMCpoolee is offline
post #20 of 28 (permalink) Old 05-12-2010, 12:30 PM
Word
Fasttimez's Avatar
This is not for a Transmission concern....this is added to your engine oil to stop injector sticking issues....but according to Rev-X you cannot run this in an automatic transmission, only systems like Manual Transmissions, Differentials, Power steering, Transfer case and Engine.... Etc...
Human Verification
