6.0L Won't Start. HELP! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-07-2010, 12:05 AM Thread Starter
Hi, I'm new to forum and need help. I have a 2005 F-350 with a 6.0L. Went out the other morning and it would turn over fine, but wouldn't start. In Nov 09 had EGR, EGR Cooler, HPOP replaced. Not a minutes trouble since that fix until now. Gave code P06111 on Saturday, checked oil pressure today and it's good. Sprayed WD40 in intake, fired up and then quickly died. Any and all help is appreciated....
FORD350GA is offline
post #2 of 10 (permalink) Old 04-07-2010, 04:45 AM
m-chan68
m-chan68's Avatar
Re: 6.0L Won't Start. HELP!
P0611 is the infamous FICM death code. In plain English, the FICM needs to be replaced. P0611 means that the PCM "saw" FICM_M power drop to less than 45 volts. Peak FICM_M voltage is anywhere between 47.5 to 49.0 volts. Given the fact that your truck doesn't start and/or stay running at all, I wouldn't be the least bit surprised that FICM_M on your truck has dropped to as low as the 20s.
Ford Diesel/Senior/Master Tech
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 10 (permalink) Old 04-07-2010, 11:38 AM Thread Starter
I had it taken to a friends shop yesterday. Can we check the FICM voltage on the scanner?
post #4 of 10 (permalink) Old 04-07-2010, 01:47 PM
PETE ENGR PSD
Here's a write up on it:
FICM pictures by DrQuad - Photobucket
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #5 of 10 (permalink) Old 04-07-2010, 04:07 PM
m-chan68
m-chan68's Avatar
Check your FICM_L, FICM_M and FICM_V data while it's at Key-On/Engine-Off and while you crank the engine over as you attempt to start the engine. What are the readings you get under both of the following conditions?
m-chan68 is offline
post #6 of 10 (permalink) Old 04-07-2010, 04:10 PM Thread Starter
It's at the shop now getting tested. I'll post those readings as soon as I get them. Thanks for ya'lls help so far...
post #7 of 10 (permalink) Old 04-17-2010, 12:22 PM Thread Starter
Truck update
Wanna start by saying m-chan68 has been big help in diagnosing my trucks problem. We have narrowed it down to the FICM and today I'll be taking the old one out and hopefully borrowing a good one to stick in. If I can't borrow one, then I'll be re-soldering the old one.
If anybody has any experience with this or helpful tips please send them my way.
Thanks TAMU PSD for the info. With that link you sent and a cold 12 pack what can go wrong?!?!
post #8 of 10 (permalink) Old 04-17-2010, 05:19 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
If the FICM checks out, you may want to replace the IPR, we have had 2 that were running fine, shut them off and no restart.
put a new IPR in and they run fine.
or at least pull the IPR and verify the screen is not torn.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #9 of 10 (permalink) Old 04-17-2010, 05:31 PM
Good advice, but unfortunately if the screen is torn then there is probably something else wrong as well .......
Mark
bismic1 is offline
post #10 of 10 (permalink) Old 05-05-2010, 07:33 AM Thread Starter
Well, I ended up ordering a 58V FICM from Swamps. It took them about a week to send me one, which I thought was pretty good. We installed it today and she fired up on the first try! She is running GREAT and I am very pleased with Swamps and all there staff.
Thanks guys for all your input, you've all been a big help. This is my first diesel truck and this forum has taught me alot.
Human Verification
