Hello all
I have an 07 with 120k. At 100k I had the EGR delete, head studs, new oil cooler, coolant filter system, Blue spring kit etc. done. I run an SCT on performance most the time and an Edge insight to monitor. Transmission was completely re-done about a month ago. It is straight piped. No cat.
Before the tranny and now getting worse after, I'm having a surging problem. It doesn't seem to matter how long I warm it up in the morning, it will drive fine until it shifts into overdrive/torque converter locks in around 55 ish. Then it surges like crazy. Let off gas and it goes smooth. On initial start up it idles smooth. It takes about 20 minutes of driving before it finally goes away. Drives fine after that unless u let it sit for a couple hours.
Cleaned my EBP pipe and sensor this weekend, still same issue. I run Mobil full synthetic 5w40 oil.
Any help is greatly appreciated.
Thanks.
Thanks.
