6.0L no start... Please help!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 01-05-2010, 10:54 PM Thread Starter
Mr. Bob's Avatar
I have a 2003 F350 6.0L with a no start. It does not crank over... After checking it out I found that the switched ground from the computer was not triggering the starter relay...
I jumped the ground and the truck cranks over but will not fire..
I have no fuel pump action... not getting triggered... I tried to plug the scan tool in and got no communication... I checked the computer for powers and grounds which were all good, so I took the computer and plugged it into another 6.0L truck and it started the other truck...
Any suggestions??
Thanks!
Bob
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #2 of 18 (permalink) Old 01-06-2010, 12:04 AM
MoyockPowerstroke's Avatar
Re: 6.0L no start... Please help!!!
Any suggestions??
Thanks!
Bob
I'd run it by cheezit on FTE.com
MoyockPowerstroke is offline
post #3 of 18 (permalink) Old 01-06-2010, 12:24 AM
Member
Tizzo's Avatar
How/When did it quit running?
If your gonna be Dumb, You gotta be TOUGH
Tizzo is offline
post #4 of 18 (permalink) Old 01-06-2010, 01:16 AM
You've checked all the fuses and PCM relay?
Jay03GT is offline
post #5 of 18 (permalink) Old 01-06-2010, 05:39 AM Thread Starter
Mr. Bob's Avatar
Thanks
Died while driving I believe
Yes I have... all the fuses are good and the PCM relay is working...
Mr. Bob is offline
post #6 of 18 (permalink) Old 01-06-2010, 08:19 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
You say no communication. No communication on the network or the scan tool doesn't turn on? Does the cigarette lighter work? Datalink power is tied to the lighter, not the power point.
This thing really sounds like it lost key power. PCM turns on the fuel pump relay. Does the FICM even cycle the injectors when you turn the key forward?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 18 (permalink) Old 01-06-2010, 11:27 AM
bring the chain
kyle43335's Avatar
the computer shut down to protect itsself. all the negative outputs arent there. the samr thing happened to my truck. replace the glow plug controller. and it should be fine. let me know if this helps
kyle43335 is offline
post #8 of 18 (permalink) Old 01-06-2010, 06:42 PM Thread Starter
Mr. Bob's Avatar
The scan tool powers up but will not communicate with the vehicle. The FICM does not cycle the injectors, the computer does not turn on the starter relay or the fuel pump...
Originally Posted by kyle43335 View Post
the computer shut down to protect itsself. all the negative outputs arent there. the same thing happened to my truck. replace the glow plug controller. and it should be fine. let me know if this helps
I unplugged the glow plug controller and it still does not turn the fuel pump or any other computer controlled component on.... Should I start unplugging modules until I get communication???
Mr. Bob is offline
post #9 of 18 (permalink) Old 01-06-2010, 08:11 PM
Captain Negativity!
PSDPlayer's Avatar
This is just funny.
Email:
post #10 of 18 (permalink) Old 01-06-2010, 08:22 PM
Captain Negativity!
PSDPlayer's Avatar
I would go and check the 30amp fuse in spot 116. That's from the ignition to the pcm. As long as that is good. The first thing to disconnect would be the fan. Then start disconnecting sensors with VREF. Modules on the network would have their own issues.
Email:
Human Verification
