6.0 miss fire - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 12-24-2009, 07:30 PM Thread Starter
6.0 miss fire
Hey guys. New here. I have a 03 super duty with a 6.0. It a 350 dually 4x4 with an automatic. Heres the deal. The truck will start and idle fine. It will accelerate fine also. Once to cruising speed it starts surging and bucking in high gear. If the trans kicks down the engine is smooth. It will throw a #5 contribution code once in awhile. Number five injector has been replace three times in the last couple of months. No change in how the truck runs. The dealer can't figure it out. Once they told me the truck needed to be ripped down until they find the issue. The next time a different tech same dealer sad it needed all eight fuel injectors.
Any thoughts would be great. Thanks.
By the way Merry Christmas!
jstroker is offline
post #2 of 13 (permalink) Old 12-25-2009, 12:32 AM
huck2080's Avatar
Re: 6.0 miss fire
maybe a break in the wiring harness
huck2080 is offline
post #3 of 13 (permalink) Old 12-25-2009, 12:45 AM
iceman89m's Avatar
Re: 6.0 miss fire
Torque Converter shudder ??????
Had the same problem with mine .....
same year and model also.....
03 6.0 8" Dick Cepek suspension,PJ Dirt Grip 37X14.50X16 mounted on Polished DC-1, 3 1/2" exhaust with 4" core glasspack,Frantz TP Bypass,Bullydog Triple with outlook and AEM Brute Force intake
RIP Will Iott
iceman89m is offline
post #4 of 13 (permalink) Old 12-25-2009, 01:09 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: 6.0 miss fire
Sounds to be an injector issue since its #5 cylinder.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #5 of 13 (permalink) Old 12-25-2009, 01:20 AM
FordBoy86's Avatar
Re: 6.0 miss fire
If the injector has been changed, and the problem is still present, i would think its something eletrical. As you increase engine rpm's the miss or stumble would become less noticeable. Any smoke or power differences? Or just the surging you were talking about?
But like Iceman said to torque converter shudder would do the same thing also
'94 F-350 4x4 DRW 5spd
Intake, DP, IDM Mod
FordBoy86 is offline
post #6 of 13 (permalink) Old 12-25-2009, 01:58 AM
The Unseen Mod
RescueF250's Avatar
Re: 6.0 miss fire
Nope not on my 6.0, it miss stumble shaked all to hell the more throttle I gave it. Believe me I know I delt with it since July as most already know here. Come to find it it wasnt. My lpop gears were eating the front cover which then got into my oil traveled up into the filter passed the filter thru my valley then thru the HPOP, thru the oil rails and into my injectors, every injector I pulled out was clogged by something in the spool valve each time it was a piece of aluminum. But thats worst case and what happen to me.
I doubt the Torque Convertor would throw a cylinder contrubition code, it comes does to that cylinder, injector, eletrical, mechanical at least you narrowed it down. #5 is also the 2nd cylinder back on the passenger side if you decided to take it out on your own its pretty easy I can do it in about an hr or less.
03 Rescue is Dead
post #7 of 13 (permalink) Old 12-25-2009, 12:27 PM Thread Starter
Re: 6.0 miss fire
No smoke. I thought the elecrical might be the issue but while the engine is running I can move, bend, and pull the injector harness and no change. The FICM has also been change for this issue.
Wouldn't #5 be the third one back on the passenger side?
I don't think the torque converter is the issue. I guess you could call it a jerking condition also. You can defenetly tell there is a dead or very week hole when in over drive.
jstroker is offline
post #8 of 13 (permalink) Old 12-25-2009, 12:41 PM
Re: 6.0 miss fire
Yes 3rd one on passanger side
04 f250 5in stacks.
pwstroke199 is offline
post #9 of 13 (permalink) Old 01-09-2010, 04:32 AM Thread Starter
Re: 6.0 miss fire
Got the truck back today. I tried a different shop. The truck runs great. They had it for awhile. The owner said it stumped them at first. But there was no dignos fee just parts and labor to do the job. He said he had never see it before but the cam lobe on for the exhaust for cylinder #5 was almost gone.
But anywho. See runs like a brand new truck.
jstroker is offline
post #10 of 13 (permalink) Old 01-09-2010, 04:43 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: 6.0 miss fire
Was the lifter for #5 exhaust replaced along with the cam?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
Human Verification
