Just got finished with oil cooler change and everything went well other than a antifreeze leak on one of my EGR delete gaskets. On the section of the delete kit that replaces were the cooler would have been there is a shaft with an o-ring seal and then a block off plate with an O ring seal on the bottom side of the intake. one of the two gasket is leaking and I'm not sure which so I would just assume replace both. However I cannot find anywhere that sells just replacement gaskets. Does anyone know where I might be able to get just gaskets for an EGR delete kit?
Well good news, didn't find anywhere that sells the replacement gaskets but i was able to take the lower blockoff plate to Oreillys and measure the shaft and get a 3/4 inch Oring for it. The larger round gasket was a little trickier. Finally found an old style thermostat housing gasket that worked perfectly after a little trimming around the outside edge. Put it back on the truck and everything is working perfectly now thank goodness.
Yeah, it definitely got me out of a tight spot. Looked all over Internet for EGR delete replacement gaskets and couldn't find anything other than the delete kits.
