6.0's, FICM's and Cold Start Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 10-30-2009, 03:03 PM Thread Starter
Sponsor
6.0’s, FICM’s and cold-start issues.
If your 6.0 will not start cold, the issue may be either the glow plugs or glow plug controller, or it can be the FICM (Fuel Injection Control Module). If after a long cranking with no start you get a lot of white smoke (raw unburnt fuel) out the exhaust, the problem is in the glow plug system. If you do not get any smoke, the problem is probably in the FICM.
The 6.0 injector has two solenoids on it; one turns the injector on (open) and the other turns it off (close). A few years ago, Ford came out with a new program referred to as inductive heating for the FICM, intended to combat issues with missing and rough-running during cold startup due to sticking spool valves in the injectors. This program works by running “extra” current through the close coil to generate heat and warm up the spool. On paper it was an excellent idea, and I advised a lot of potential injector customers to have their FICM’s reflashed rather than buy a set of injectors.
Based on my testing, it appears that the early models of FICM’s only used the inductive heating when the EOT was less than 48*F or so. The “first” updated heating strategy turned it on any time the EOT was less than 184*F, meaning every time you started the truck if it was shut off for more than 10 minutes! Ford’s newest update to the heating strategy has it coming on below 148*F; better, but that’s still a lot of current draw.
Unfortunately, there have been some very serious consequences.
Although the FICM on the 6.0 is way more “intelligent” than the IDM on a 7.3, its basic job is to convert 12VDC to 48VDC and deliver this to the injectors at the proper time. Under normal operating conditions, the FICM typically draws 6-7 amps at 12V into the FICM power supply, which is well within its design limits. However, with the inductive heating active this current draw increases to 24-32 amps—it pegs the 30 amp meter on my test bench! Although the FICM power supply is capable of sustaining this load for short periods of time (1-2 minutes) it eventually gets very hot.
If this was all that happened, things wouldn’t be too bad, but there are several components on the printed circuit board that were not properly soldered during the manufacturing process, and as the PCB heats up and expands, the solder under these components cracks and they lose their electrical connection. The FICM’s 48 volt power supply is actually four separate or independent units; if one of the four goes down, the other three can supply enough current to run the truck, even with the inductive heating active. If two of the four go out, the truck will start and run normally as long as it is warm out, i.e. as long as the inductive heating does not turn on. If three of the four go out, the truck will probably not start or run unless it is at full operating temperature, and even then it may not start. If the injector voltage is over 35 volts, they run OK, although not as well as when it is 48 volts. If the voltage drops below around 24 volts, the injectors cannot fire. While most scan tools will display the FICM voltage, they do not always show the correct value. For instance, AutoEngenuity can only display voltages between 40 to 56 volts, so if the voltage is 35, it will display 40.
How to check your FICM for proper voltage output.
(Perform this check when the engine is completely cold.)
1. Remove the two bolts that hold the coolant reservoir to the cowl and push the reservoir out of the way forward and to your right. You do not need to disconnect any of the hoses.
2. On top of the FICM is a small cover held on by two #20 Torx screws; remove these two screws and pry the cover off.
3. On 2003 and early 2004 trucks, you will see 7 screw heads under the cover. On 2004 and later trucks you will see 4 screws.
4 screw FICM
4. Take a multi-meter set on DC volts and connect the ground lead to battery negative, and with the key ON measure the voltage at the screw on your right—closest to the driver’s side fender. Do not let the probe short against the case! The voltage should be right at 48 volts. Anything between 47 and 49 is good.
5. Have an assistant cycle the key and measure the voltage during the initial key-on buzz test. Voltage should not drop below 46 volts.
6. Next measure the voltage while cranking the engine. If voltage stays at or above 45-46 volts, the FICM is fine. Abnormally low battery voltage can give a false low FICM voltage reading, so make sure your batteries are good.
The procedure is the same for FICM’s with 7 screws, except that you will be checking voltage at a different screw, as shown in this picture.
7 screw FICM
If the voltage is above 46 volts in all the tests, your FICM is in excellent condition. If it is between 36 and 45 volts its OK, but not great. If it is between 25 and 35 volts, you have serious FICM problems.
We (Swamp’s) are able to repair most FICM’s with low voltage problems, but some units may be either fried beyond repair, or the time it would take to repair them would be more than a good used FICM costs. If you send your unit in to us for repair, the price is $350.00 if we can repair it. There is no charge if we can’t fix it. Return shipping via FedEx Ground is $15.00. We can also step the voltage up from 48 to 58 volts for an additional $50.00. All units have a 1-year warranty. Due to a lack of FICM cores, you will have to send your unit in for repair, and since I am the only person who fixes them, it will be about a week for me to turn it around. (I do almost my electronics work at home during the weekends) If you have an extra FICM or two, we’re interested in trading to build up our stock of cores.
We are only doing hardware-level modifications as opposed to software / code changes, so having your unit reflashed at a dealership will not cause any problems. Also, please note that we cannot reprogram FICM’s. For that, we recommend Power Hungry Performance or Innovative Diesel.
Jonathan
Early 99 7.3, Gen3 HPOP, 175/146 Inj's, PI converter
Custom 7.3 Tuning w/ Cylinder Pressure Testing
Advanced Vehicle Diagnostics & Troubleshooting
Swamp is offline
post #2 of 34 (permalink) Old 10-30-2009, 03:09 PM
Banning Smut
PTSUPERD's Avatar
Re: 6.0's, FICM's and Cold Start Problems
Very nice Jonathan. I looked at your images to try to fix...but the format is correct.
PTSUPERD is offline
post #3 of 34 (permalink) Old 10-30-2009, 03:13 PM
Busy Busy
Marty's Avatar
As always, awesome post.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 34 (permalink) Old 10-30-2009, 03:56 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Wow very nice post, I am guessing this FICM low power issues is just rearing its head now cause I never say any posts about it being the culprit last winter or the winter before when my truck was running crappy.
I think mine is more injector that FICM since I get black blue and grey smoke on startups, lately its been more blue but I am gonna try this test just to make sure. Thanks
How does this 48-58v mod work? will this shorten the life of the FICM? Will it aid in cold starts?
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 34 (permalink) Old 10-30-2009, 05:31 PM
2Cruel
moremph's Avatar
good post jon, brings back memories of ford-diesel.com posts!
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #6 of 34 (permalink) Old 10-30-2009, 05:42 PM Thread Starter
Sponsor
The High-Voltage mod to the FICM's is the same basic idea as the High-Voltage mod that people do to the IDM's in the 7.3's. It's not a huge power gain, but people have consistently reported that their trucks run a little better. I don't believe it will shorten the FICM's life, but we offer a 1-year warranty on them. I started doing these in March of this year, and haven't had any units fail yet.
FICM's have been failing and being replaced on a regular basis; it's just that until now no one know why they were failing.
Jonathan
Swamp is offline
post #7 of 34 (permalink) Old 10-30-2009, 05:57 PM
6Leaker
jdc753's Avatar
Thanks again the for the info, definitely some good stuff.
Sounds like a modded FICM with some tuning would be a hot ticket. Gonna have to get back to checking ebay for them.
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #8 of 34 (permalink) Old 10-30-2009, 06:00 PM
Banning Smut
PTSUPERD's Avatar
Just FYI. Jon's links in his OP have been fixed.
PTSUPERD is offline
post #9 of 34 (permalink) Old 10-30-2009, 06:54 PM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Nice informative post.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #10 of 34 (permalink) Old 10-30-2009, 09:24 PM
Jeremy's Avatar
I guess I missed it...but which of the seven screws do you test?
great post
thanks
Jeremy
16 6.7 F-350 XLT SC 4x4 auto
06 6.0 F-250 XLT SC 4x4 auto
05 6.0 Excursion EB 4x4 auto
00 7.3 F-350 Lariat CC 4x4 12 speed
95 7.3 F-Superduty XL PSD Auto Mechanics Truck
94 7.3 F-Superduty XL PSD 5 Speed 12ft Flatbed
93 7.3 F-Superduty XL IDI 5 Speed 12ft Dump bed
Jeremy is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/10-6-0l-power-stroke-technical-info/43705-6-0s-ficms-cold-start-problems.html
Posted By For Type Date
Ford F-350 no cold start. (Engine No start Ford F-350) This thread Refback 11-26-2015 03:21 PM
Hard to start W/codes 06 6.0l - Diesel Bombers This thread Refback 11-19-2015 03:01 AM
