Water in fuel light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-11-2009, 06:49 AM Thread Starter
Water in fuel light
Hey guys
I have a question about my truck, its an 04 king ranch with the 6.0 and the water in fuel light has just started to come on in the last two days. i filled the tank up and put some power service cetane boost in. What confuses me is the light will come on but it will only stay light for about 5 mins or so. Why??
Also, ive tried draining the seperator on the frame and for some reason i cannot find the right size allen wrench to take out the plug and im really afraid of stripping it. Does anyone know the actual size??
Any help would be greatly appreciated.
bigrob54 is offline
post #2 of 11 (permalink) Old 10-11-2009, 02:41 PM
Re: Water in fuel light
i think its either a 6mm or 7mm i want to say 7. some one here will chime in.
04 f250 5in stacks.
pwstroke199 is offline
post #3 of 11 (permalink) Old 10-11-2009, 04:19 PM
Steamfighter
Steamfighter's Avatar
Pull the sensor and clean it while your under there . a friend of mine had a problem with his and when we pulled the sensor it was NASTY . Real easy to clean a and put back .
2006 F350 6 wheeler. some mods done thanks to First Coast Diesel Performance , but more to come!! .
Steamfitter local 602 Washington D.C.
2005 F250 OVERLOADED WORK HOSS
Steamfighter is offline
post #4 of 11 (permalink) Old 10-12-2009, 12:33 AM
it is size 6, sometimes you have to drain it several times to get it all out
Peter
2008 F-250 XLT FX4, 556 HP 1059 TQ
H&S Mini Maxx, DPF/DOC Delete, AFE Intake, Airdog
pistolpete837 is offline
post #5 of 11 (permalink) Old 10-12-2009, 04:06 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
definitely 6mm allen mine is locked in pretty solid and I think I am going to be pulling the entire unit off the frame to get the plug out without cracking the case.
If your interested Ford now has a tool-less drain plug that they use on the LCF trucks, Diesel Technician Society
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #6 of 11 (permalink) Old 10-23-2009, 07:28 PM
No Hole Too Deep or Slopy
mines a 6mm and deffinatly clean the sensor if u drain it and it comes on again, mine was a little gunked up and thats what cause the light not water
Blow-n-Smoke is offline
post #7 of 11 (permalink) Old 10-23-2009, 08:50 PM
Its a 6mm....the tool-less ones like on the LCF and 6.4L are junk....best bet is to modify a long allen key (cut the short end a little shorter) which will make clearance between the pump and 4x4 drive shaft easier. I take a piece of brake line that is curved at the end (points right at the sensor) and blow air through it at the sensor to clean it off and the rest of the housing inside. I always replace the fuel filters (even if its a little before they are due) when the water seperator has to be drained.
95 Dakar M3 (daily) - 3.0L I6 fully built engine/heads, supercharged, meth injected, and some other goodies...520rwhp, 483rwtq, 10.684 sec@127mph
03 Black SVT cobra (wkend warrior) - ported SC, pulleys, built IRS (no wheel hop!!)and front suspension, and more...586rwhp, 611rwtq, 10.889 sec@121 mph
WTB: 2005-2007 6.0L!!
03SVTcobra is offline
post #8 of 11 (permalink) Old 10-23-2009, 08:56 PM
6Leaker
jdc753's Avatar
really? they are junk?
I just changed to one, mostly because the old plug had to be destroyed to get it out, and since I thought it would be easier to have something I could get a good bite on if things get fouled up again.
I don't think the pervious owner ever drained the pump on my truck and by the time the light came on it was too frozen solid to even budge. Impact gun with a 6mm key in it just stripped the plug, ended up drilling it out, and then after all that had to scrape at the sides of the opening to clean all the oxidation and junk out of it so the new plug would actually seal.
Inside around the drain and sensor had TONS of rusty gunk in it which looked like it cause the plug to basically fuse to the cover.
On the plus side I can now pull the HFCM in maybe 10 minutes, might actually be faster to pull it to change the filter
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #9 of 11 (permalink) Old 12-08-2009, 02:36 AM
Having the same problem with my 08. Are the sensors hard to get out???
b.crow_68 is offline
post #10 of 11 (permalink) Old 12-09-2009, 12:26 AM
well the plug is a 6mm but it will not most likely come out. if you do get it out then you are good. go to ford and get the new steel one. if not then you will need the little side cover that the lines go into. but it will have the new steel plug in it. the tooless ones are junk dont get one.
2003 Std Longbed 5sp, AirDog, Smarty TNT-R, Dual CP3s, FTE 250hp Nozzles, Fluidamper, 110# Valvesprings, Pushrods, Valair Clutch With Billit Input Shaft, 64/71/13/ over 91mm/HT4C Twins, Head Studs, Boost, Rail pressure, Fuel pressure, Egt, Water Injection, 1550 U-Joints
Pony_Kegger is offline
Human Verification
