2003 F250 6.0 Oil Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-27-2009, 05:13 PM Thread Starter
I can chase an oil leak to somewhere at the rear top of the engine. Turbo and accessories blocking my view even with a mirror. It comes from under a heat shield above the top of the bell housing when I view from underneath on the driver's side. Are there any videos/manuals that would show removal and replacement of the Turbo Charger to get a view of the area in question. I am a carpenter by trade not a mechanic and could use some help.
Thanks,
Lou
lbarattini is offline
post #2 of 5 (permalink) Old 04-28-2009, 02:22 AM
POWERSTROKER's Avatar
Re: 2003 F250 6.0 Oil Leak
Is it wet toward the front of the engine?
I see alot of oil cooler gasket leaks, they start at the front and run toward the rear of the engine.
could also be a HPOP cover gasket, over time they tend to flatten out and not seal as well
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #3 of 5 (permalink) Old 04-29-2009, 07:50 PM
All done now
Arisley's Avatar
I am betting either turo pedistal o-rings or HPOP line o-rings.
Look in this thread, there is a turbo removal video in there.
http://powerstrokenation.com/forums/...ad.php?t=27551
Never mind, just now noticed it was a 6.0
Last edited by Arisley; 04-29-2009 at 07:51 PM. Reason: Didn't read the OP good enough.
Arisley is offline
post #4 of 5 (permalink) Old 04-30-2009, 06:29 PM Thread Starter
There is some oil residue in the valley between the heads. This was caused by the oil filter cannister o-ring leak which I replaced. The main leak at the top rear of the engine still persists and is much heavier than what was coming from the o-ring leak at the filter.
Thanks,
Lou
post #5 of 5 (permalink) Old 05-01-2009, 03:44 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
ICP sensor ???
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
Human Verification
