FICM 48v or 58v? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 12-09-2013, 12:47 AM Thread Starter
Strokin Roughneck
txdieselmech84's Avatar
Send a message via Yahoo to txdieselmech84
FICM 48v or 58v?
What are if any the disadvantages to bumping my ficm up to 58v? Ive read a few cons to doing the upgrade but I wanted to hear from my fellow PSN members that might have some technical insight.
txdieselmech84 is offline
post #2 of 31 (permalink) Old 12-09-2013, 04:22 AM
Re: FICM 48v or 58v?
the ones ive seen have had noting but peoblems, they like to eat injectors but thats just what ive seen with the 58v ficm
1997P-stroke is offline
post #3 of 31 (permalink) Old 12-09-2013, 10:23 PM
My truck has a Swamps 58vlt FICM, that the orig owner had installed. It is at 162k+ and just replaces #7 injector last week. Testing the FICM, it puts out 54-55 volts during key, starting and then idling. I have used archoil 9100 and has HSS in it. I cannot give insight on bow the truck ran before the Swamps FICM. From my reading OEM injectors start going out between 150-200k miles. Truck runs great and starts easy in cold weather.
- Will
2006 F350 CC SB
OEM Air box / Zoodad
Blue Spring Update
SCT (Canned for now)
ScanGauge II
MBRP 4" TB w/Kitty MIA
CCV Mod'd
6" Fabtech lift (going to a 4 or 4.5")
35" DC FC-II & 18" Moto Metal
Cobra 75WX / Wilson 500
SDER1 is offline
post #4 of 31 (permalink) Old 12-10-2013, 03:26 AM
Fuel it up again Dummy
Mhatlen's Avatar
Send a message via MSN to Mhatlen
I myself would go with 48 volts but that's me.
I have heard it does start better and is better when cold.
Just seems to me another 10 volts=more coil heat every cycle?
2006 F250 Lariat CCSB 4X4, ARP Studs, O-Ringed heads Fass 125, Cat EC-1, IPR coolant filter, SCT Tuner w/PHP custom tow tune, Atlas40, Updated Turbo lines/stc/standpipes/D-plugs, DC Power 270 amp, 4" SS exhaust w/Corsa, Amp Steps, Die Hard AGM Platinums, Icon coils Carli/Deaver leafs 7" of lift, All on Fatty Daddy Toyo MT 38/15.50/18
47k miles
Mhatlen is offline
post #5 of 31 (permalink) Old 12-11-2013, 01:52 PM
import basher
carguyz28's Avatar
350k on my 04 with the .58v ficm and so far not one problem. I'd recommend doing it. My fuel mpg increased slightly, starts much easier in cold, I'm in Canada where it is stupid cold for 6 months out of the yr. -40c before windchill. And that is my snow plow truck. I got my from g&j diesel in billings mt.
a real man drives a truck so mean, that the mere thought of mashing the go pedal could result in instant death
carguyz28 is offline
post #6 of 31 (permalink) Old 12-11-2013, 02:58 PM
I heard and it makes sense but it came from a Ford engineer that the main disadvantage of a 58V is with the added voltage. You can expect added electrical wear on the injectors.
Early 99 F250, T-500, Regulated Return, D66, Eliminator Diesel Stage injectors , TS tuned by Eliminator Diesel
14fan77 is offline
post #7 of 31 (permalink) Old 12-12-2013, 03:39 AM
jammin60's Avatar
I'm a big fan of the Bullet Proof Diesel selectable one. I have been running it on the 53v setting for almost 2 years. I have had the truck since new and it's still on its original injectors it has 160k on the clock and like 3900hrs. Crisp starts and good performance from what I have seen.
2006 CCSB 4x4 ARP studs, FCDP egr delete and coolant filter, SCT tuned by Innovative, 6.4 banjos, MBRP 4" Turbo back, Edge Insight CTS, Blue Spring Kit, 160amp alt with remote rectifier from Quick Start, Icon 2.5", toyo mt's
Made for work by Ford, Made for fun by FCDP
So how is that Hope and Change workin out for ya?
jammin60 is offline
post #8 of 31 (permalink) Old 12-12-2013, 03:52 PM
'05 Excursion
Term3's Avatar
I'm not an electrical expert but at work when they modify components such a solenoids they often boost the voltage and this actually reduces their amp draw and its my understanding that its high amps that build heat.
Sent from AutoGuide.com App
Term3 is offline
post #9 of 31 (permalink) Old 12-12-2013, 04:17 PM
radioflyer's Avatar
x2 for swamp's FICM 58v.
2008 F250 CCSB LARIET
578HP/1188TQ MAY 2013
JUST ANOTHER FORD
radioflyer is offline
post #10 of 31 (permalink) Old 12-12-2013, 09:47 PM Thread Starter
Strokin Roughneck
radioflyer....x2 for Swamps? explain please?
Human Verification
