6.0 starter wont engage first try when engine oil is cold, NEED Help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-07-2013, 11:32 PM Thread Starter
wiredupfiredup03
wiredupfiredup03's Avatar
Unhappy 6.0 starter wont engage first try when engine oil is cold, NEED Help.
I have a 2003 f-350 with the early 6.0L engine. I replaced the starter a year ago due to the starter rod turning but not engaging the flywheel. The new starter did the same thing however it would only do it on cold starts, and after 2-5 tries the starter would engage and start the truck. Also on 80 plus degree days it would start first time even if engine is cold, but if its 50 or below it takes a few tries. I turn key for start and I hear the starter rod spin but not engage flywheel, I will stop for a few seconds and try try try till the starter engages flywheel and it starts. All mechanics i show it to are stumped and i need help, also flywheel was inspected with no issues.
wiredupfiredup03 is offline
post #2 of 10 (permalink) Old 06-08-2013, 01:08 AM
Banned
Re: 6.0 starter wont engage first try when engine oil is cold, NEED Help.
Its possible you could have gotten a bad starter.
I had one a while back whee the Bendix would not also slide out. I took it back to the ford house and they gave me another one. New one has never had a problem.
miller45103 is offline
post #3 of 10 (permalink) Old 06-08-2013, 01:22 AM
Administrator
Zmann's Avatar
thats what I would be thinking
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #4 of 10 (permalink) Old 06-08-2013, 02:09 AM
Fixing Broken Stuff
toolmangary's Avatar
^^ Me too
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 10 (permalink) Old 06-08-2013, 02:37 AM Thread Starter
wiredupfiredup03
Yeah but the old starter did the same thing and new one does it when its cold outside, however it could be -10 out and as long as the truck is warm from running recently it will have no issues starting on first try. What my guess is if it could be solenoid going bad?
post #6 of 10 (permalink) Old 06-08-2013, 02:52 AM
Administrator
Zmann's Avatar
good point
but you made it sound like the starter spun at all times but wouldn't engage when cold ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 10 (permalink) Old 06-08-2013, 03:27 AM Thread Starter
wiredupfiredup03
Ok when its cold that is when starter spins but no engage until I cycle a few times and then after about 2-5 tries it will engage and start, I will drive it long enough till engine temp gauge moves a little and turn it off (a quick drive to local store), I will then start it first try no problems. Its as if engine temp and outside temp determine if it will engage on first try. Weird i know.
post #8 of 10 (permalink) Old 06-08-2013, 05:11 AM
Administrator
Zmann's Avatar
well if the starter is spinning the bendex action should chuck the gear out and engage the flywheel
even if it were a tad slow spinning for some reason
but you can try the solenoid or replace the starter if it has a warranty swap it out or at least that's how I would proceed
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 10 (permalink) Old 06-08-2013, 08:06 AM
Blue Hawg's Avatar
I Agree with the others responses. Only issues I've ever seen with starters related to temps is the starter overheating and not functioning properly. Can't say as I've ever seen one function incorrectly due to cold weather. If I were to think cold weather would effect anything it would more than likely be the batteries. It should be warrantied if purchased recently so pull it off and take it for an exchange. At most if it doesn't fix the issue you're out a lil time, oh and maybe a busted knuckle or two.
'04 CCSB Lariat FX4 DRW, EGR Delete, Firestone bags with In-cab controls, AIRRAID CAI, Coolant Filter, SCT X4 with ID Extreme Street, Street, and Tow, Blue Spring Upgrade, B&W Flip Hitch, stock Alcoa 5-stars wrapped in Kenda Klever M/T, CAT ELC, new oil cooler install coming soon.
Blue Hawg is offline
post #10 of 10 (permalink) Old 06-08-2013, 01:54 PM
Jackleg Mechanic
mastrkee's Avatar
Maybe oil is somehow getting in/on the bendix or somewhere in/on the starter and causing a restriction of some sort. Cold oil thick, hot oil not so much.
Just a thought.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
Human Verification
