ICP location?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-01-2008, 12:27 AM Thread Starter
beast6.0's Avatar
ICP location??
could someone tell me where to find or have a pic of the ICP on an 05 6.0L.... I need to try and see if my hpop is causing my problem..... Thanks
06 F-350 CC Dually 4x4
beast6.0 is offline
post #2 of 4 (permalink) Old 12-01-2008, 12:32 AM
diesel tech
diesel71's Avatar
Re: ICP location??
the icp sensor is in the passenger side front valve cover
the icp regulator is under the turbo toward the driver side in the rear.
diesel71 is offline
post #3 of 4 (permalink) Old 12-01-2008, 12:40 AM Thread Starter
beast6.0's Avatar
Re: ICP location??
I was aslo wondering what the small vaccum pump on the passenger wheel well is used for. I runs constantly now and I don't remember it doing that before...
beast6.0 is offline
post #4 of 4 (permalink) Old 12-01-2008, 12:45 AM
diesel tech
diesel71's Avatar
Re: ICP location??
tsb05-17-04.pdf
the vacume pump is for your heater controls and 4x4 auto hubs if you have them. some trucks also have a vacume control shut off valve in the heater core hose to close off coolant flow when max ac is set on. If it is running constantly you have a vacume leak somwere or it needs replaced.
diesel71 is offline
Human Verification
