6.0 Cold start problems and Problems running when cold - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 11-11-2008, 10:52 PM Thread Starter
I have a 06 F350 and am having problems starting it when it's cold and problems with it running when its the slightest bit cold. I have a S&B CAI and a magnaflow 4" Turbo back exhaust on it. Had the truck chipped but took the chip off and that doesn't seem to be making a difference. Anytime I go to start my truck in the morning it takes a very long time to start, it sounds like its about to start, or that its started but as soon as I stop turning the key over the truck just dies right away. Once I finally get the truck started it runs really bad until the temperature is right in the middle. Once the truck warms up it runs fine. When I try to drive the truck when its cold, the truck stutters alot and doesn't want to rev uo, it also blows out a little bit of white smoke, but once its warmed up it doesn't blow out any at all. I've also had some overheating issues when towing my 6000lb trailer up some hills (not sure if this would help at all but figured I would throw it out there). I've recently replaced both fuel filters and that didn't seem to make a difference. Any suggestions would be greatly appreciated.
JayB22 is offline
post #2 of 21 (permalink) Old 11-11-2008, 10:57 PM
Village Idiot
LRTMatt's Avatar
Re: 6.0 Cold start problems and Problems running when cold
Most likely your EGR cooler has chit the bed. Many times a plugged oil cooler can be a concern at the same time. If you don't get the EGR cooler replaced and keep overheating it, headgaskets will quickly become a concern as well.
LRTMatt is offline
post #3 of 21 (permalink) Old 11-11-2008, 11:10 PM
POWERSTROKER's Avatar
Is your coolant res. full? If it it I doubt your EGR cooler is leaking.
Is your check engine light on? If it is do you have a way to pull te codes?
Exactly how cold are you talking about? could be a glow plug issue.
Does it fire right up when its hot? if it does then prolly not an ICP problem.
The overheating may be cause by an inoperative fan clutch, there is a connector on the driver side of the fan shroud, make sure that is plugged in and make sure that the fan blades have not torn those wires apart.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #4 of 21 (permalink) Old 11-12-2008, 12:19 AM
Proud Sponsor
Abrannan19's Avatar
what oil are your running?
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #5 of 21 (permalink) Old 11-12-2008, 03:15 AM Thread Starter
My truck doesn't want to start all that great anytime it sits for a while but is worse anytime it's around 5-10 deg Celcius. As for when the truck is overheating the coolant reservior is full and never seemed to go down, and it doesn't overheat a whole lot, it's just on a couple long hills. I never let it get too bad, I usually just pull over and let it idle to cool down. I'll check to see if my fan clutch is plugged in. Also my check engine light never has come on. As for the oil I'm running, its not synthetic and its 15w40 oil thats in it. The engine turns over really good as I just replaced my batteries and it has no problems turning it over.
JayB22 is offline
post #6 of 21 (permalink) Old 11-12-2008, 04:13 AM
Lost Cause
Betaracer's Avatar
If you are still covered under warranty, have a reputable dealer test the injector contribution and the FICM under cold conditions. Also, check coolant pressure under hard load.
Betaracer is offline
post #7 of 21 (permalink) Old 11-12-2008, 08:36 PM
casper7.3's Avatar
whats the milage and oil change intervals? once its started and warmingup does it act like its running on two cylinders then three then four until its warmed up and running smooth? an 06 is a little new for injector issues but if the glow plugs are operating corectly thats what i'd lean toward. i've put many a one in for this type concern in the 03-05's again if all else is ok.
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #8 of 21 (permalink) Old 11-13-2008, 12:08 AM Thread Starter
The millage is around 86,000 miles. I change my oil every 5,000km so around the 3,000mile mark. I"m not 100% about what my warountee covers now but will call the dealer and find out. I just dont want to bring my truck in there, have them work on it and tell me that I owe a couple thousand for a fix that isn't covered under warountee and for one that I possibly could have done myself. Whats the best way to make sure that my glow plugs are working properly?
Casper, it does kind of seem that way while it warms up. If the temp gauge is right at the bottom it doens't want to move at all, but as the temp guage starts to rise it will stutter for a bit and slowly accelerate and slowly gets better and better until the temp guage is right in the middle.
JayB22 is offline
post #9 of 21 (permalink) Old 11-13-2008, 02:00 AM
Stock parts suck!
zs6.0's Avatar
I had the same problem with mine last winter and again a few weeks ago.I wound up replacing 3 injectors,EGR cooler,and the fan clutch.Everything was warranty work at 76000.If you go to the dealer have them check those three and the oil cooler and you should be able to find the problem.
2005 F-250 4x4 SC LB
SCT X3 Elite Diesel with Insanity,K&N intake,7" Custom black single,33" BFG MTs,Usual gauges,ARPs,RCD egr delete,Southbend SD,Zoodad,updated STC,Recon lights,Black Onyx HG,and a tab at Ford SOLD
2002 Reg. Cab 6sp.
Tyrant tunes,straight piped, fuel/boost/pyro, SB single, AIH delete, 6637,Recons, and a pile of parts waiting
zs6.0 is offline
post #10 of 21 (permalink) Old 11-13-2008, 02:18 AM
Sponsor
dalpilot's Avatar
It sounds like you have a few sticking spool valves in the injectors. Did it just start doing it, or was it a gradual progression to where its at now?
dalpilot is offline
Human Verification
