A/C clutch noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-18-2013, 06:31 AM Thread Starter
Juniorssrollin's Avatar
A/C clutch noise
Hey guys, recently upon starting the truck and the AC compressor cycles on, it makes a slight shudder, ALMOST grinds. When it does this you can smell like oil come thru the vents.
After I get the truck moving it stops and never hear it again.
Air is cold so compressor is working, so is the clutch shot or low on oil?
Sent from AutoGuide.com App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #2 of 8 (permalink) Old 03-18-2013, 09:22 PM Thread Starter
Re: A/C clutch noise
Bump!!
post #3 of 8 (permalink) Old 03-20-2013, 12:31 AM
Fixing Broken Stuff
toolmangary's Avatar
I have seen a few compressor clutch bearings fail, if it makes noise with the clutch disengaged then its probably the bearing.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 8 (permalink) Old 03-20-2013, 12:41 AM
Horsepower Enthusiast
sho669's Avatar
I'd lean towards the bearing failing as well, another not so uncommon failure for the 6.0!
I usually just replace the compressor as a whole unit since most of the time people wait untill they melt before considering it an issue, the shaft seal usually starts leaking shortly after that.
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.90@94.627
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo LSX and chassis work
sho669 is offline
post #5 of 8 (permalink) Old 03-20-2013, 02:46 AM
1sd
1sd's Avatar
My '06 makes the grinding sound when I first turn on the A/C if I haven't run it for a while. I don't get any kind of smell from it though. It's done it since new. I used to have a Ford based motor home that did the same thing. Don't know if it's normal or not but mine seems to be fine.
Steel Gray, 2006 SD CC, XLT Lariat, 8" Fabtec lift on 37/14.50x20 Falken Wild Peaks. 20x10.5 Moto Metals. Quad Fox Shox Reservior on all corner, 4.56 ring and pinions, Baja Designs 8" Sol Tec lights, Amp Research electric steps. Kenwood head unit, Yeasu FT8800 tri-band ham, Lowrance Elite 5M GPS. Snug Lid bed cover with Bed Rug liner.
1sd is offline
post #6 of 8 (permalink) Old 03-20-2013, 10:34 PM
sho669's Avatar
Never really worked on motorhomes but the ambulances would actually blow apart compressors, crazy seeing them blown in half, there was a reflash to fix it. Not sure what it changed but it worked.
sho669 is offline
post #7 of 8 (permalink) Old 03-20-2013, 11:26 PM Thread Starter
Cool thanks guys, guess I'll put a compressor and orifice screen on it.
post #8 of 8 (permalink) Old 04-30-2013, 08:53 PM
it just cost me $1787 to have my whole air system replaced because the compressor failed and i got metal shavings thoughout the system..it didn't make much noise for very long and then it just setup and snapped the belt...leaving me stranded.
compressor, condensor, fittings, and god knows what else is added to the list of parts i've had to replace since the warranty stopped...and i only have 70,000 miles on this 06..
2013 F350 lariat 6.7 bone stock
isimar is offline
Human Verification
