2006 6.0 oil leak PICTURES INSIDE - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-15-2012, 11:49 PM Thread Starter
hey guys i have a 2006 f450 with 6.0 and i noticed today a few wet oil spots under it and after looking around in the parking lot at where i usually park its been leaking for a while.it is dropping from the bell housing and the starter is covered in oil, also i popped the hood and there was a large amount of oil on the bottom side of the hood and alot down on the valley of the engine. i took pictures so hopefully some one will be able to help me out. thanks alot in advance
vids of my lowered f250
blake b is offline
post #2 of 11 (permalink) Old 10-16-2012, 12:41 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: 2006 6.0 oil leak PICTURES INSIDE
check the blue boost boot on the outlet of turbo
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #3 of 11 (permalink) Old 10-16-2012, 02:19 AM Thread Starter
just checked the hose and it appeared to be good but what i did find is on the dip stick the part that slides down over the dipstick tube is broken off and basically the handle is sitting right on top of the tube. could oil make its way all the way up the tube and spray out the top? in the pic you can see the part thats broken off its slid down the tube a little way
blake b is offline
post #4 of 11 (permalink) Old 10-16-2012, 02:24 AM
SnowWhite6.0's Avatar
Run it and check the oil cap or the oil filter houing .. seen both of them crack before ... Best thing to do is spray it off and drive it and see where it comes from
SnowWhite- hot tune, head work, stuff deleted, little more air flow. Your not so typical 6.slow
Previous truck- 95 12v 550hp. Lots of fuel lots of timing.. head work big sticks... SOLD to younger brother
-Jordan
SnowWhite6.0 is offline
post #5 of 11 (permalink) Old 10-16-2012, 02:55 AM
whistle tits
ghohouston's Avatar
looks like you also have quite the exhaust leak there...
ghohouston is offline
post #6 of 11 (permalink) Old 10-16-2012, 03:17 AM
I agree with the bad exhaust leak and I also think it may be the oil filter cap/housing leaking. Follow the oil towards the front of the vehicle and to the highest point.
lenzhotrod is offline
post #7 of 11 (permalink) Old 10-16-2012, 03:34 AM
Bubbawagsf250's Avatar
no its not from the dipstick tube cause
i have the samething on my truck that
little part is gone and it never leaked
Bubbawagsf250 is offline
post #8 of 11 (permalink) Old 10-16-2012, 04:39 AM Thread Starter
Checked the oil cap everything is dry and i srarted ot and looked around and camt see oil physically coming from anywhere really the valley is the only thing covered in oil if that helps
blake b is offline
post #9 of 11 (permalink) Old 10-16-2012, 04:45 AM
Certified Engine Destroye
treetechsixOH's Avatar
Easiest way to find an oik leak like that is to soak the engine in degreaser for about 15 minutes, rinse with a hose. Let the truck idle until you find where its leaking from. I did one the other day. I started the truck and went a did something else for about 20 mins. After returning i found the leak immediately. The glow plug connector had come unseated.
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
treetechsixOH is offline
post #10 of 11 (permalink) Old 10-16-2012, 05:27 AM Thread Starter
I will do that first thing in the morning
blake b is offline
Human Verification
