6.0 Not starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-25-2012, 05:00 AM Thread Starter
6.0 Not starting
Hey all I've got a late 2004 6.0 that will not start... The guy drove it, shut it off then it would not start back up... good ficm, new icp, good low pressure oil, new batteries a month ago and no raw smoke... any ideas where I should start? I just did a EGR delete and new oil cooler a month ago and it's been running great up until today.
2010 F350 cc/lb Innovative tunes, WOP EGR delete, Airaid intake, H11 head studs, 4' straight piped exhaust
2005 F250 cc/lb 6.0 EGR delete, 4" straight piped exhaust, AFE Pro-Dry intake
ben97 is offline
post #2 of 13 (permalink) Old 09-25-2012, 06:28 AM
Fuel it up again Dummy
Mhatlen's Avatar
Send a message via MSN to Mhatlen
Re: 6.0 Not starting
Have you tried unplugging the icp, that will put pcm in default for 30 seconds
FICM 48v always while cranking +or-
icp during crank?
ipr during crank?
2006 F250 Lariat CCSB 4X4, ARP Studs, O-Ringed heads Fass 125, Cat EC-1, IPR coolant filter, SCT Tuner w/PHP custom tow tune, Atlas40, Updated Turbo lines/stc/standpipes/D-plugs, DC Power 270 amp, 4" SS exhaust w/Corsa, Amp Steps, Die Hard AGM Platinums, Icon coils Carli/Deaver leafs 7" of lift, All on Fatty Daddy Toyo MT 38/15.50/18
47k miles
Mhatlen is offline
post #3 of 13 (permalink) Old 09-25-2012, 01:18 PM
Fixing Broken Stuff
toolmangary's Avatar
What do you have for fuel pressure? codes? what is your ICP?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 13 (permalink) Old 09-25-2012, 04:50 PM Thread Starter
Im not sure havent had a chance to check all of that stuff... The truck threw an ipr code and all eight injector circuit low code and also a ficm circuit low code....I put the ficm out of my 6.0 in it and it cleared all codes but still wouldnt start... His ficm started my truck just fine... im srarting to wonder if it is a short but where would i start?
ben97 is offline
post #5 of 13 (permalink) Old 09-25-2012, 09:54 PM
Mhatlen's Avatar
Try unplugging the ICP and see if it starts. Also when you unplug it look at the pigtail for oil. If the ICP is leaking oil odds are it's shot.
Sounds to me like the ficm is bad being all the injector codes cleared for the injectors after switching out.
Also the ICP can kick out some low circuit IPR/ICP codes if it's bad.
Try unplugging it and try to start..........
47k miles
Mhatlen is offline
post #6 of 13 (permalink) Old 09-26-2012, 04:18 AM Thread Starter
Ok will do tomorrow... I installed his Ficm into my 6.0 and my truck fired right up. im ruling out the ficm for now but when i put his ficm back into his truck all eight injector codes came back.. im starting to think its the ipr or even the hpop. Is there a way to test the ipr?
ben97 is offline
post #7 of 13 (permalink) Old 09-26-2012, 04:42 AM
ewxlt's Avatar
Sounds like hpop.
2006 F250 CC FX4 leveled on 285/75/18
by
, on Flickr
ewxlt is offline
post #8 of 13 (permalink) Old 09-26-2012, 07:23 AM
Mhatlen's Avatar
I'm sure there is, it's a variable resistance pressure sensor that the pcm uses to open and close the ipr valve to keep injector pressure where it needs to be throughout the rpm range. How to test it I don't know lolbut if you have oil in the pigtail plug odds are the high pressure is blowing through it and once the oil gets in the sensor it looses it's ability to adjust resistance because oil has continuity and it becomes a closed circuit. more or less.
See what unplugging the ICP does for starting, unplugging it will put pcm into a 30 second default on the ipr.
Your IPR % will tell you if you have a standpipe/STC problem (leak) or a hpop issue.
Gotta get sleep, working thing really wrecking my life.
47k miles
Mhatlen is offline
post #9 of 13 (permalink) Old 09-26-2012, 01:59 PM Thread Starter
Ok ill be sure to try that tonight...Im also wondering if maybe my 2005 FICM is not compatible with his 2004 even though his worked in my truck? Funny how my ficm cleared every single code in his truck but would not start. But then when his ficm is installed back into his truck all the codes of a bad ficm come back. I hate to just start replacing parts
ben97 is offline
post #10 of 13 (permalink) Old 09-26-2012, 07:07 PM
Mhatlen's Avatar
The ficm,s will work, there are different flashes more than likely.
Not sure why one would throw cels unless the pcm in your newer truck has a different pcm strategy and sees more points? Are you showing sync/12v power/48.5v logic with a scanner ??
Do year hear the injector buzz and fuel pumps come up on pressure ?
47k miles
Mhatlen is offline
Human Verification
