6.0 p2099 code - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-08-2012, 01:23 AM Thread Starter
07 fx4 superduty..6.0
6.0 p2099 code
Will this low boost code cause the truck have hard starts? When I'm at a complete stop my edge is showing 1 lb of boost . Hoping someone can tell me what it might be before I pull the turbo.
keblmo is offline
post #2 of 7 (permalink) Old 09-08-2012, 03:29 AM Thread Starter
Re: 6.0 p2099 code
Nobody???????
Too late I'm pullin it!!!!
keblmo is offline
post #3 of 7 (permalink) Old 09-08-2012, 08:15 AM Thread Starter
Re: 6.0 p2099 code
Pulled it looks pretty damn clean. No heavy build up and the unison ring is perfect . Gonna clean her up and check the boot tomorrow. Wtf was ford thinking putting that bolt way in the back?????
keblmo is offline
post #4 of 7 (permalink) Old 09-08-2012, 12:41 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 6.0 p2099 code
Usually that P0299 code means the unison ring and veins need cleaned. I think that vertical back bolt on your 07 is easier to get out than the 03-04's which are horizontal.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 7 (permalink) Old 09-08-2012, 02:20 PM Thread Starter
Re: 6.0 p2099 code
Thanks for the response tool guy ..... I'm gonna clean it now!
keblmo is offline
post #6 of 7 (permalink) Old 09-08-2012, 04:11 PM
Re: 6.0 p2099 code
Sticking turbo may be the most common cause of the code, but P0299 is a code that can come from anything from turbo, ebp sensor or plugged tube, icp issues, high pressure oil issue, low side oil volume issue, ficm concerns (especially low voltage), failing injectors, low battery voltage or alternator issue, fuel pressure, egr valve, damaged MAP sensor or hose, etc. To know for sure will require more troubleshooting.
Mark
bismic1 is offline
post #7 of 7 (permalink) Old 09-08-2012, 09:47 PM Thread Starter
Re: 6.0 p2099 code
Got it back in!
Works perfect... 24 lbs of boost (factory) no tunes?
Replaced the hot side boot ....88.00 bucks.
That's probably all it was to begin with but, the turbo's cleaned.
Thanks to the guys that did respond.
It was easier than I thought it would be.
keblmo is offline
Human Verification
