Low boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-21-2012, 03:15 AM Thread Starter
Low boost
I have '04 6.0 with exhaust, sinister egr delete, and a sct livewire tuner. im using the canned tunes that came with the livewire cause i cant find anyone in my area to make a custom tune. i wasnt paying too much attention at first but i started using the livewire to monitor the pids and i noticed my boost pressure wouldnt climb above 11 psi. My truck is running just fine and isn't throwing any codes but i think i should be seeing more boost than that. I checked all intercooler boots and everything else i could think of. Any ideas will help im at a loss here.... im planning a camping trip soon and im hesitate to pull my toyhauler if im gonna have a problem with the truck. thanks
chrlskn123 is offline
post #2 of 11 (permalink) Old 08-21-2012, 06:04 AM
Buy Low Sell High
onebad97's Avatar
Re: Low boost
Maby your tuner is reading wrong. Idk but I would think you would notice only 11 psi of boost. Espically when 6.0 put put like 40psi at wot. Just a thought.
1997 F250 Psd, 5-speed, 4X4, ecsb, single mass fly wheel, 3" down pipe, stright piped, 6 position Ts performance chip, boost & egt glow shift gauges. Leveling kit.
onebad97 is offline
post #3 of 11 (permalink) Old 08-22-2012, 02:40 AM Thread Starter
Re: Low boost
Im kinda thinking the same, like i said the truck is running just fine. i just like to be able to keep an eye on temps and boost and stuff. Which sensor reads boost is it the map sensor, or is there a boost sensor. my tuner reads off of the OBD2 so if my tuner is saying 11 pounds then is the engine reading the same?
post #4 of 11 (permalink) Old 08-22-2012, 02:52 AM
justind's Avatar
Re: Low boost
While it shouldnt be 40 your sensor or gauge is not reading correctly. It should be mid to high 20's easy.
05 F350 CCSB 6.0, 4" MBRP, SCT/Looney, CTS, 275
Rugged Terrains
justind is offline
post #5 of 11 (permalink) Old 08-22-2012, 04:11 AM
Buy Low Sell High
onebad97's Avatar
Re: Low boost
I have a 7.3 so Idk a whole lot about all the electronic stuff. But you could always get a vacume/ boost guage and tap into your map sensor line and take it for a spin. That way you can see if it really is only putting out 11 psi or if there is something else going on. And I'm guessing there is a boost sensor because the 05 and up 6.0 had boost guages stock in the dash. Idk if they were electronic or off a boost line. like I said I'm a 7.3 owner so I'm not to up on all the electronic stuff. Wish I could help more.
onebad97 is offline
post #6 of 11 (permalink) Old 08-24-2012, 02:25 AM
justind's Avatar
Re: Low boost
It is an electric 29psi sensor
Rugged Terrains
justind is offline
post #7 of 11 (permalink) Old 08-24-2012, 04:58 AM Thread Starter
Re: Low boost
Thanks for the help guys, i thinking it s the map sensor. when i use my tuner to check the map pid an alert comes on right away saying the value is too high. does anyone know what normal values are for the map. My tuner is set from the factory to alert at 27 but it was reading in the 100's at an idle.
post #8 of 11 (permalink) Old 08-29-2012, 01:30 AM
brute_mt's Avatar
Re: Low boost
I don't have a SCT but I do have a Scan Gauge II. I know on my SCII I have it programed to read boost off of the map sensor. The SCII uses a math equation and the map sensor reading to show boost. Maye you're reading 11 as the map sensor and not truely boost??? I'm not sure on the normal readings for a map sensor because it depends on your elevation above sea level. Here in Montana I believe it's around 13.5ish.
1997 F250 SCLB XLT, 3" downpipe, DIY 6637, 285/75R16 BFG ATs, Scanguage II
SOLD: 2004 F-350 CCSB Lariat, 285/75R16 Toyo M-55s on Mickey Thompsons, K&N intake, EGR delete by Sinister, Coolant Filter by Sinister, Cat ELC, Blue Spring Mod, 6.4 Banjo Bolts, Scangauge II, billet grille insert, debadged
SOLD: 2000 F-250 SCSB XLT Auto
brute_mt is offline
post #9 of 11 (permalink) Old 08-29-2012, 02:02 AM
Banned
Re: Low boost
I know I had some pinhole tears in my boots, but couldnt see them. I would double check em, but thats just me.
miller45103 is offline
post #10 of 11 (permalink) Old 08-29-2012, 02:17 AM Thread Starter
Re: Low boost
Thanks everyone for the input, i found the problem yesterday. The small hose going to the map sensor was cracked almost all the way around down by the manifold so i kept missing it. So i was loosing boost and also the map wasnt reading properly. The hose was so stiff when i took it off it cracked in a couple other spots. So it was a simple fix and im back to reading good boost at the tuner and truck seems to be running a lil bit better than before. i plan on replacing all the boots soon any way, just trying to find some that will last but wont break the bank.
Human Verification
