FICM REPAIR KIT - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-17-2012, 05:32 PM Thread Starter
STOCK06's Avatar
FICM REPAIR KIT
Does anyone know where to purchase a FICM repair kit?
STOCK06 is offline
post #2 of 7 (permalink) Old 08-17-2012, 06:33 PM
Administrator
Zmann's Avatar
Re: FICM REPAIR KIT
like what a soldering gun and solder?
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #3 of 7 (permalink) Old 08-18-2012, 04:00 AM
Fuel it up again Dummy
Mhatlen's Avatar
Send a message via MSN to Mhatlen
Re: FICM REPAIR KIT
There are guys who have repaired ficm,s themselves not sure where they get the diodes and what have ya parts. I have one open now and I can tell you this: There are a million tiny tiny parts in those things. If you botch the job it may ruine it and you can have a problem having someone work on it much less warranty their work after you tried?
After saying that if you have needle tips for a soldering gun and are familiar with how to fix electronics on circuit boards go for it. I have seen a repair procedure on FTE.
2006 F250 Lariat CCSB 4X4, ARP Studs, O-Ringed heads Fass 125, Cat EC-1, IPR coolant filter, SCT Tuner w/PHP custom tow tune, Atlas40, Updated Turbo lines/stc/standpipes/D-plugs, DC Power 270 amp, 4" SS exhaust w/Corsa, Amp Steps, Die Hard AGM Platinums, Icon coils Carli/Deaver leafs 7" of lift, All on Fatty Daddy Toyo MT 38/15.50/18
47k miles
Mhatlen is offline
post #4 of 7 (permalink) Old 08-18-2012, 03:29 PM
Administrator
Zmann's Avatar
Re: FICM REPAIR KIT
most guys re flow the solder on the power supply to repair them sinc cold solderr joints were the issue = no parts required
if you need a capacitor ETC most guys wouldn't know how to even test to see what one is bad ,,
there are a few articles on what to order to do a voltage upgrade but honestley by the time you order all the stuff you might as well send it off or buy a Bulletproof unit
no one touches the logic side when doing an upgrade or repair to the voltage so the million tiny parts isn't an issue IMHO
but yes if you botch it your looking for a new power supply because no one wants to wok on a DIY fail
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 7 (permalink) Old 08-23-2012, 02:09 AM Thread Starter
STOCK06's Avatar
Re: FICM REPAIR KIT
Who does the best work? Not interested in voltage upgrade...waste of money for no gains IMO.
STOCK06 is offline
post #6 of 7 (permalink) Old 08-23-2012, 04:32 AM
Re: FICM REPAIR KIT
ficmrepair.com
Mark
bismic1 is offline
post #7 of 7 (permalink) Old 08-23-2012, 04:45 AM
Administrator
Zmann's Avatar
Re: FICM REPAIR KIT
your" gains" opinion isn't really supported with fact for some of the vendors options
and there is no "FICM repair KIT" not sure where you got that ?
it is a few bad solder joints and the articles are a plenty on the DIY repairs
ficmrepair.com is great for folks who want a PHP flash / voltage upgrade (you don't care for) or can't solder and need their OEM re soldered ,,because they do not want to try and then have a scrap power supply
with the 6 phase Bulletproof FICM
you get a choice of voltages you select after you receive it by selecting jumpers /or just stay stock
a triple redundancy ( yes a huge advantage ) ,, not to mention an all new improved power supply/heatsink/potting material and a company Who cares
they also do repairs to stock FICM's
DTR's Donation page
RIP DTR Ron
Zmann is offline
Human Verification
