SNOW STAGE 2 INSTALL QUESTION - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-07-2008, 05:51 PM Thread Starter
1999F350's Avatar
Send a message via Yahoo to 1999F350
IM INSTALLING A STAGE 2 SYSTEM ON A 2005 F350 6.0 EVERYTHING IS HOOKED UP AND CONECTED. THE PROBLEM IM HAVING IS THAT WHEN I TURN THE ARM SWITCH ON THE PUMP ACTIVATES. I HAVE THE SETTINGS TO THE LOWEST {COUNTERCLOCKWISE} WHATS THE PROBLEM??? THANKS IN ADVANCED JAY
1999.5 F350 XLT EXT CAB AUTO 4X4,K&N W/6037, DPF5,HIGH IDLE,80T,80E,120R,140BOOSTFOOLER,PHANTOM2 GAUGES BOOST,TRANS, EGT,CUSTOM 4R100 W/ JWVB,BILLET HARD PARTS,427LINE,RACERX PARTS,BD PAN,6.0 COOLER,DETROIT TRU TRAC,3.73,VAN TURBO W/ATS&HIFLO OUTLET,4" STRAIT PIPE,AFE INTAKE MAN,140V IDM,325/60/20 NITTOS,2.5"LEVELKIT,OPTIMA'S,PIONEER DVD/NAV
1999F350 is offline
post #2 of 9 (permalink) Old 08-07-2008, 07:00 PM
unaccountably transformed
bootstrap1002's Avatar
Re: SNOW STAGE 2 INSTALL QUESTION
is the pump sprayin or just on
bootstrap1002 is offline
post #3 of 9 (permalink) Old 08-07-2008, 07:33 PM Thread Starter
1999F350's Avatar
I TURNED THE START PRESSURE UP TO 10 THEN 20 ETC STILL SAME THING. SEEMS TO ME THERE IS APROBLEM WITH THE CONTROLER???
1999F350 is offline
post #4 of 9 (permalink) Old 08-07-2008, 08:51 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Might be the controler, or it sounds like you have the power running to the pump, not the controler...
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #5 of 9 (permalink) Old 08-07-2008, 09:12 PM Thread Starter
1999F350's Avatar
power is running to the controler
1999F350 is offline
post #6 of 9 (permalink) Old 08-07-2008, 09:18 PM
CSIPSD's Avatar
Then I would say something is wrong with the controler. check all your connections again.
Joe
CSIPSD is offline
post #7 of 9 (permalink) Old 08-07-2008, 09:44 PM Thread Starter
1999F350's Avatar
checked everything 10 times. i contacted snow havent herd back yet.
1999F350 is offline
post #8 of 9 (permalink) Old 08-08-2008, 12:22 AM
Power Stroke Psychiatrist
Power Smoker's Avatar
ignition 12v to switch, from switch to control box. output wire from control box to pump. it's probably green or white. red is typically 12v ignition power on the snow system. either the control box is bad or you're reading the destructions wrong.
Wayne Yates
Power Smoker is offline
post #9 of 9 (permalink) Old 08-11-2008, 03:13 PM Thread Starter
1999F350's Avatar
sending controler back to snow. let youall know what happens.
1999F350 is offline
Human Verification
