Bent push rod/ broken rocker - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-13-2012, 07:03 AM Thread Starter
smokie07's Avatar
Cool Bent push rod/ broken rocker
Ok guys I have a bent rid and broken rocker arm on cyl 2! I was told it had low compression on this cyl but pulled valve cover and found this so should I just fix these and recheck compression or just go ahead and pull heads
1995 F250 RCLB 7.3 4x4 zf5
1997 F350 SRW RCLB 7.3 4x4 E4OD
smokie07 is offline
post #2 of 17 (permalink) Old 08-13-2012, 07:29 AM
Real Trucks Rattle!
Strokin450's Avatar
Send a message via Yahoo to Strokin450
Re: Bent push rod/ broken rocker
I had one go out in my mustang, I played it safe and pulled the heads because you have no idea what else could be wrong. Better to play it safe and just have it at least checked.
96 F250 ECLB Intercooler Mod, , 3" downpipe--> 4" straight pipe, 1.1 A/R housing, TS TW tunes, Skyjacker all 4 corners, Maximum boost/pyro/trans gauges, Ion wheels/Nitto tires,Banks trans command, TQ and Valve body upgrades, 160k
2008 CRF-450R- It's a HONDA but still wish it was diesel
2006 Honda Rincon 680 mud machine
Strokin450 is offline
post #3 of 17 (permalink) Old 08-13-2012, 09:57 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
tap the valve with a hammer, I bet its damn near seized
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #4 of 17 (permalink) Old 08-13-2012, 10:10 PM
IHPowerstroke7.3's Avatar
Gotta be a reason why the pushrod bent, I agree with ctc deezul I would make sure you don't have a stuck seized valve. I wouldn't pull the heads until you know the valve is stuck. I have seen pushrods bend for no reason. I'm guessing its intake side since you said it was low on compression?
IHPowerstroke7.3 is offline
post #5 of 17 (permalink) Old 08-13-2012, 10:46 PM
codykthekilla's Avatar
Garage
you better hope its not a lifter issue or you might be pulling that engine to put a new cam in.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #6 of 17 (permalink) Old 08-13-2012, 10:57 PM
Usually a broken lifter will either not open the valve or keep the valve open depending on where it is stuck. However an easy way to check this, use a good pushrod, put it in the lifter and either have a friend bump the key over or with the key off, unplug the starter wire ( Right hand fender by vacuum reservoir) and put it to the positive and bump it over. Hold a little tension on the end of the pushrod with your finger (BE CAREFUL) and watch the pushrod to make sure it is moving up and down. If you're unsure of the movement, compare it to the next known good cylinder. If it doesn't move at all, make sure you have it seated correctly. If is is, bad news.
post #7 of 17 (permalink) Old 08-13-2012, 11:24 PM
That was going to be my question, Why do the pushrods bend on these 6.0's? I see alot from bad install after removal other than that, why? Most common are siezed valves or a floated valve, but what are most people finding on these? And as said earlier I hope it is not a lifter.
lenzhotrod is offline
post #8 of 17 (permalink) Old 08-14-2012, 12:08 AM
Hood Rich
CTC DEEZUL's Avatar
I have only come across one bent pushrod and broken rocker arm. It was due to a guide freezing up. It was on a manual trans truck that is heavily over loaded. These things in manual form are easy to over rev so I assume that was the main cause
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #9 of 17 (permalink) Old 08-14-2012, 09:30 AM Thread Starter
smokie07's Avatar
Mine is a f350 flatbed and it came from a lease return from a construction company out of Louisville ky so I bet it's had the guts pulled out of it
smokie07 is offline
post #10 of 17 (permalink) Old 08-14-2012, 09:33 AM Thread Starter
smokie07's Avatar
First time messing with heads do valves go up or down to open?
smokie07 is offline
Human Verification
