No start hot 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-12-2012, 02:25 PM Thread Starter
Angry No start hot 6.0
New hpop/ipr/icp/injectors starts and runs when cool all this was installed 3 days ago truck is still in the shop because of the hot start issue anybody have any ideas
Mo6.0 is offline
post #2 of 15 (permalink) Old 05-12-2012, 03:07 PM
mantis118's Avatar
Re: No start hot 6.0
Stand pipes.
mantis118 is offline
post #3 of 15 (permalink) Old 05-12-2012, 04:41 PM
Check the d plugs and stand pipes. Most likely the snap to connect fitting though. I would start there. Who is doing the work? Sounds like they are just throwing parts at it.
runs2rch is offline
post #4 of 15 (permalink) Old 05-12-2012, 06:59 PM
We need to know what year model the truck/engine is to give you a proper answer.
Mark
bismic1 is online now
post #5 of 15 (permalink) Old 05-12-2012, 09:51 PM
theGreenHornet's Avatar
dummy plugs
Will
2006 CCSB F250 Lariat
Edge CTS / SCT (ID Tunes) / Cooper / Diamo / Pioneer / UWS / PMM / Recon
SOLD: 2000 F-250 Lariat CrewCab ShortBed 4x4
Dynatrac / Rough Country / Mazzi / Toyo / WARN / MBRP / Recon / DP-Tuner / Kenwood / JL Audio / Western Diesel /
theGreenHornet is offline
post #6 of 15 (permalink) Old 05-13-2012, 12:50 AM
03's and early 04's don't have dummy plugs or STC fittings - if he happens to have one of those model years. I realize that the odds are that it is an 05 or up, but it would be nice to know for sure. An o-ring could have been cut when installing the oil rail, etc.
So you are saying after all that work it will start cold, but not hot, AND that is what it went into the shop for originally?
Has anyone done an air pressure leak test?
Mark
post #7 of 15 (permalink) Old 05-29-2012, 10:31 PM Thread Starter
Angry Re: No start hot 6.0
03 first gen 6.0 stc fitting replaced along with hpop and now o-rings on stand pipes starts very easy cold still only reading 320 icp when hot
Mo6.0 is offline
post #8 of 15 (permalink) Old 05-29-2012, 10:37 PM Thread Starter
03 first gen. 6.0 yes still the same issue even after new o-rings onthe stand pipes I'm totally stumped
Mo6.0 is offline
post #9 of 15 (permalink) Old 05-29-2012, 10:39 PM Thread Starter
Sorry new to this no to
My knowledge no air pressure leak test
Mo6.0 is offline
post #10 of 15 (permalink) Old 05-30-2012, 12:42 AM
Apply 100 psig shop air to the ICP sensor opening (remove ICP and install adapter fitting), close the IPR valve (apply 12 V for only 1 minutre at a time), and listen for air leaks.
Mark
Human Verification
