6.0 Oil Leak at turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-10-2012, 03:54 AM Thread Starter
Stock Sucks!
SaNnDnSurF's Avatar
Truck leaks oil right under the turbo you can see a small puddle, replaced turbo drain o-ring and still leaking the mechanic I use works at ford is acting like he's stumped only leaks down the back of the motor while the truck is running and for a couple mins after it shuts off any suggestions here? 05 6.0 110k miles
05 CCSB 6.0
ARP Studs and Egr Delete
8" Rize
22" RBP Wheels 37" Toyo M/T's
AFE intake & 8" Mbrp Stack
SCT With Innovative Tunes
RBP Grille
Amp Steps
And some other bling
SaNnDnSurF is offline
post #2 of 10 (permalink) Old 05-10-2012, 04:36 AM
Jackleg Mechanic
mastrkee's Avatar
Re: 6.0 Oil Leak at turbo
maybe the HPOP cover leaking. unless you can see it on the drain tube. there's a o-ring on both ends.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 10 (permalink) Old 05-10-2012, 05:44 AM
Monster758's Avatar
STC fitting? I was having a similar problem. Didn't think much of it at first. Truck shut down 30 min outside of Vegas. 600 dollar tow service to 1000 dollar repair.
2005 F-250 Custom 4" TB exhaust, AFE Stage II, High Idle Mod, CCV Mod, 6 Inch Fabtech, 35/16 wide Dick Cepek tires
Monster758 is offline
post #4 of 10 (permalink) Old 05-10-2012, 01:04 PM
Fixing Broken Stuff
toolmangary's Avatar
STC fitting would create a internal oil leak.
Maybe pull a inner fender well then you can see the back of the engine better.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 10 (permalink) Old 05-10-2012, 01:11 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
truck wont hot start if it was an stc fitting...
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #6 of 10 (permalink) Old 05-10-2012, 01:13 PM
BRING DA AMBALAMPS
that's what I said over on psa too....give those a look
post #7 of 10 (permalink) Old 05-10-2012, 01:17 PM
bgc
I mangled the lip of drain tube refitting the turbo causing a leak, quite oblivious it was dripping down the tube.
bgc is offline
post #8 of 10 (permalink) Old 05-11-2012, 12:47 AM Thread Starter
Stock Sucks!
SaNnDnSurF's Avatar
Thanks for the quick responses guys we replaced the oring again and all seems well now he said it looks like it didn't seat the first time. Fingers crossed lol
05 CCSB 6.0
8" Rize
RBP Grille
Amp Steps
post #9 of 10 (permalink) Old 05-11-2012, 03:18 AM
Diesel Addict!!
DeereMan83's Avatar
dont feel bad. I did the same thing when I put my 03 turbo on.Ive got to where I have plenty of o-rings laying around!
05 F250-6.0 FX4,Zoodad,58V FICM,PHP FICM tune,EGRD,Studs,155/30's,S&B,CFM+ LM,ELC-1,4"MBRP/Silverline,Powermaxx,Gogo,Harley Grill, 08 gate-20"s-door panels,console,Edge CS,VT365 IH Dressing, Westin BG,Updated FX4,STC,GN hitch,Line-x,PMM Coolant filter with deere filters, NFAB 6-step
If its not a Deere, It must be a Puss!!
DeereMan83 is offline
post #10 of 10 (permalink) Old 06-24-2012, 01:35 PM
Gambled and Lost 6.oh
ksieckmann's Avatar
Mine started leaking after putting 03 turbo on last night, going to pull it tonight and check o ring , that was my first guess too.
'05 CCSB FX4
Deleted, Studded, SCT w/ Vivian's Looney Wild, Warrens 190cc. DieselRX
ksieckmann is offline
Human Verification
