6.0 EGR delete question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 03-26-2012, 03:15 PM Thread Starter
I just purchased a 2005 6.0L 6 speed 4x4 F350 SWB. The guy told me the EGR had been deleted but I want to MAKE SURE it has. How can I visibly check this to know if I need to order a kit or not? I have dealt with 7.3 and 6.9 engines but this is my first 6.0.
Rdh605 is offline
post #2 of 27 (permalink) Old 03-26-2012, 05:30 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 6.0 EGR delete question
Look under the intake manifold on the right side and see if the cooler is still there, also see if EGR valve is still in the intake manifold.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 27 (permalink) Old 03-26-2012, 05:32 PM
Depends on if they did a block off plate or a real delete look under the turbo on the left side under the intake and see if you see it
501outlaw is offline
post #4 of 27 (permalink) Old 03-26-2012, 05:35 PM
6.0 powerstrokregt cooler - Google Search
See the blue hose that's part of the egr
post #5 of 27 (permalink) Old 03-26-2012, 05:36 PM
http://www.performanceboats.com/gall...a/500/0212.jpg
Sorry click on this link
post #6 of 27 (permalink) Old 03-26-2012, 05:36 PM
whistle tits
ghohouston's Avatar
It will be a long square tube under the passenger side of the intake man. It will have a blue or orange connection to your oil cooler if its stock still. Maybe take a pic and post it up on here? Or email it to ghohouston@hotmail.com
ghohouston is offline
post #7 of 27 (permalink) Old 03-28-2012, 12:10 PM Thread Starter
It still has the EGR in it. Now to delete or try to keep it clean and working. How difficult is the deletion to do? I have heard an SCT or Gryphon programmer can solve the problem without deleting the EGR, any thoughts on that?
Rdh605 is offline
post #8 of 27 (permalink) Old 03-28-2012, 02:11 PM
whistle tits
ghohouston's Avatar
Physically the delete can be done in a few hours if you know what youre doing
post #9 of 27 (permalink) Old 03-28-2012, 02:59 PM
'05 Excursion
Term3's Avatar
A full delete is the best way to go if your state allows it. Tuners will keep the EGR valve closed but it doesn't protect you if your cooler springs a leak. Even if you remove the EGR valve leave it plugged in for proper fan clutch operation.
http://www.thedieselstop.com/forums/f21/egr-delete-will-fan-work-not-275000/
Term3 is offline
post #10 of 27 (permalink) Old 03-28-2012, 03:11 PM
Just do a real delete if that cooler gets a leak you'll have more problems to worry about
Human Verification
