6.0 wont start when warm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 03-11-2012, 02:34 PM Thread Starter
roach's Avatar
a cpl weeks ago when i showed up on the job(50 miles from shop)i shut my truck(06 f250 6.0) off and was checking out the site.i went to move my truck and all it would do is turn over,no start. i grabbed my tools and started working. at lunch i tried again and it started. it has been doing this since. when i drive it long enough to get it warm and then shut it off it wont start for at about an hour.any ideas until income tax gets here and i can take it to the shop?. thanks
2002 f350 7.3
2006 f250 6.0
roach is offline
post #2 of 39 (permalink) Old 03-11-2012, 02:55 PM
Re: 6.0 wont start when warm
Sounds like you have a internal high pressure oil leak. Pipe connection at pump or branch tubes. Fun to fix and hard to diagnose.
02-7.3 is offline
post #3 of 39 (permalink) Old 03-11-2012, 05:14 PM
lubeowner's Avatar
Easy to diagnose and easy to fix. If you do it yourself it is about a $20 part. Take you about 1 hour to fix maybe 2 since it is your first time.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #4 of 39 (permalink) Old 03-12-2012, 02:40 AM
Turbodiesel6.0's Avatar
Do you know if your truck has the updated STC fitting? If not then most likely that is the problem however an air leak test should be done just to be sure. Although your not going to to be replacing that in 2 hours as stated above.
2005 F350 XL 4X4 6.0PSD
221K
Muffler/Cat Delete, Sneaky up-pipe, Warren Diesel Injectors, ScanGaugeII, Pillar Pod W/AutoMeter Sport Comp-Boost, trans, Pyro, Homemade Coolant Filter, Blue Spring Upgrade
Turbodiesel6.0 is offline
post #5 of 39 (permalink) Old 03-12-2012, 03:01 AM
lubeowner's Avatar
It doesnt have a stc problem.
Jeremy Johnson
dieseldr.net
post #6 of 39 (permalink) Old 03-12-2012, 03:37 AM
stroked99_1/2's Avatar
I do love how anytime someone has a HPO issue on 04-7 everyone automatically says it MUST be STC.
stroked99_1/2 is offline
post #7 of 39 (permalink) Old 03-12-2012, 04:49 AM
theGreenHornet's Avatar
please elaborate, my friend is having the same problem with his 06
Will
2006 CCSB F250 Lariat
Edge CTS / SCT (ID Tunes) / Cooper / Diamo / Pioneer / UWS / PMM / Recon
SOLD: 2000 F-250 Lariat CrewCab ShortBed 4x4
Dynatrac / Rough Country / Mazzi / Toyo / WARN / MBRP / Recon / DP-Tuner / Kenwood / JL Audio / Western Diesel /
theGreenHornet is offline
post #8 of 39 (permalink) Old 03-12-2012, 12:06 PM
lubeowner's Avatar
I know that you have fixed a lot of trucks with these similar starting issues. How many of those stc fitting have been the actual problem?
Jeremy Johnson
dieseldr.net
post #9 of 39 (permalink) Old 03-12-2012, 02:18 PM
Let me think.... None.
post #10 of 39 (permalink) Old 03-12-2012, 03:16 PM
lubeowner's Avatar
bingo! When the sct fittings go bad it comes apart creating a no start at all temps or the truck dieing while going down the road. No start hot is not an stc fitting.
Jeremy Johnson
dieseldr.net
Human Verification
