6.0 shut off while driving down the road!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 (permalink) Old 02-29-2012, 11:48 PM Thread Starter
so it would not idle . Thought it was a fuel problem as i filled it out of my bulk tank in the rain. Added diesel 911 still nothin. drove it home 40 miles it stalled 12 times but started rite back and never missed a beat . Shut it off in the drive way then no restart . Took it to the shop . He said bad cam sensor and a faulty battery. replaced both still lots of codes and wont run . next code was crank sensor. Replaced and nothing. To make a long story short it was the number 8 injector. That was all. No one had ever herd of one injector doing this ?? anyone on here ???
doublesrtroker is offline
post #2 of 16 (permalink) Old 03-01-2012, 12:49 AM
cobrabc1993's Avatar
Re: 6.0 shut off while driving down the road!!!
I have seen a lot of 6.0 injectors fail, but not just one that caused it too die. It must have failed severly.
2006 F250 HarleyDavidson,CCSB, 6.0, Arps, RCD delete, SCT Extreme.
1997 F350,4x4, auto, srw, reg cab, 3.55's, cold air, 4inch exhaust, chip, gauges.(Sold)
1996 F350,4x4, auto, srw, reg cab, 3.55's, bone stock.
(Builder)
cobrabc1993 is offline
post #3 of 16 (permalink) Old 03-01-2012, 12:56 AM
stoker04's Avatar
I had an issue two years ago Cylinder 6 Injector circuit low. Truck ran fine never missed a beat. Then took it out a month before Christmas truck cut off and me and nothing. Turned out that cylinder 6 injector back shorted through the ficm took out 5 other injectors, ficm harness, GEM module but never took out the ficm it did fail about 4 months later though. Lesson learned. Should have replaced the injector when it through the code
2004 F350 6.0 ECSB Lariat. All the normal stuff
stoker04 is offline
post #4 of 16 (permalink) Old 03-01-2012, 04:09 AM
06kingranch37's Avatar
I also had the same issue in my truck the ipr #### the bed
06kingranch37 is offline
post #5 of 16 (permalink) Old 03-01-2012, 09:00 PM
I have seen the injector harness short on the intake manifold bolts, causes random codes and stalling or no starts strange running concerns, The harness gets sqweezed under the air intake tube from the air filter. When you start taking it apart and moving things around the condition goes away, typical 6.0 wire chaf thing. When this happens it sets dtc,s for cam and crank sensors and sometimes injector circuit codes. Lots of wire chaffing problems on both the injector harness and engine harness in that area by the intake manifold,valvecover, on bank two under the air inlet tube from the air filter. But it sounds like they got it handled just a thought.
lucky's diesel is offline
post #6 of 16 (permalink) Old 03-03-2012, 12:10 AM
Boost Junkie
6.0&SN95tagteam's Avatar
I'm actually having a similar issue with my 6.0. When the truck is cold, it runs fine; once it has warmed up however, it either shuts off or will act like it's running into a fuel cut at ~1700-2500 rpms... Once it shuts off, it will generally start right back up. Due to my operational schedule at work, I haven't had a whole lot of time to look at it and troubleshoot, so advice on where to start looking would be appreciated.
6.0&SN95tagteam is offline
post #7 of 16 (permalink) Old 03-03-2012, 05:17 PM
Certified Engine Destroye
treetechsixOH's Avatar
Egr valve,icp,Ficm,injectors.
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
treetechsixOH is offline
post #8 of 16 (permalink) Old 03-03-2012, 06:36 PM
Jboy
Mine was doing the exact same thing. Twas throwing all sorts of injector codes. Turns out the ficm was bad. Changed it out and all the injector codes went away.
Sent from my DROID BIONIC using AutoGuide.com App
jmyrkle is offline
post #9 of 16 (permalink) Old 03-04-2012, 12:32 PM
Boost Junkie
Wouldn't the FICM/injectors being bad throw codes? As it stands right now I'm not getting any codes...
2004 F250 CC 6.0 4x4
Intake, RCD 190cc/100 sticks, RR, 4 in turbo back, deleted, studded, SRL+ by Matt @ Gearhead, blah blah blah
post #10 of 16 (permalink) Old 03-04-2012, 08:08 PM
Depends on what you mean when you say codes. When mine went bad I never had a check engine light and with a basic scanner no codes came up. With a Ford scanner it was tossing several different injector codes.
Human Verification
