Fan shroud removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 02-08-2012, 12:52 AM Thread Starter
southbend_powerstroke's Avatar
Angry Fan shroud removal
Alright guys I tried to remove my shroud to get to my fan because the clutch took a chit... I even tried drinking beer while doing it and I did nothing but smash my knuckles and hit my head. How it the hell do you remove this thing? Should I just take it in or should I do it my self with some assistance? Please for the love of the powerstroke gods help me and my little hands.
6 inch stack
35's
2.5 leveling kit
Blue spring
Stage 2 afe intake
SCT SF3
Innovative diesel custom tunes
South bend full ceramic clutch
Sinister coolant filter
Some sweet stickers
Oh and I just waxed it
southbend_powerstroke is offline
post #2 of 22 (permalink) Old 02-08-2012, 01:03 AM
09 6.4
webb06's Avatar
Re: Fan shroud removal
its easiest to drain the coolant and remove the radiator. then the fan and clutch are right there in the open. or you can loosen the fan with a fan wrench or an air chisel and spin it off. then there are 4 or 5 bolts (15mm) that hold the shroud in place. 2 directly below the intake manifold, 2 on the very bottom, and one on the drivers side about half-way up the shroud. then you can lift both the fan and the shroud out
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #3 of 22 (permalink) Old 02-08-2012, 07:57 AM Thread Starter
Sweet Jesus. How hard is it to remove the radiator?
6 inch stack
35's
2.5 leveling kit
Blue spring
Stage 2 afe intake
SCT SF3
Some sweet stickers
post #4 of 22 (permalink) Old 02-08-2012, 12:34 PM
Administrator
Zmann's Avatar
apparently it's not to bad I have been meaning to do this myself
some cut the shroud at the obvious cutting line to help with removal
I think I will do the radiator route myself
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #5 of 22 (permalink) Old 02-08-2012, 12:46 PM
This may help.
RADIATOR.PDF
lenzhotrod is offline
post #6 of 22 (permalink) Old 02-08-2012, 03:25 PM
uga33's Avatar
Radiators are extremely easy on these trucks. You will need a special tool to remove grand cooler lines if it's an 05-07 truck. I have always used ac line tools to get them off.
2012 F-350 CC/SB 4x4 King Ranch*Spartan Tuning*5" Flo-Pro*
uga33 is offline
post #7 of 22 (permalink) Old 02-08-2012, 03:26 PM
uga33's Avatar
Trans cooler*
uga33 is offline
post #8 of 22 (permalink) Old 02-08-2012, 03:30 PM
Administrator
Zmann's Avatar
Good to know
harbor freight sells em cheap
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 22 (permalink) Old 02-08-2012, 05:36 PM
It's actually very easy to do.
Remove the upper radiator hose from the neck, as well as the over flow tube connected to the radiator. Then remove the two screws (8 or 10mm) holding the shroud onto the radiator assembly. Then, remove the plastic piece behind the Powerstroke V8 Logo, and attached to the shroud, with a small screwdriver.
The shroud assembly can be removed by pulling straight up with care. Then, you will have direct access to the fan and the circular shroud which is attached to the intake.
Weathertech Floor Mats, Weathertech Window Vents, Valentine One Radar Hardwired, 5th Wheel/Gooseneck Package w/Factory Fifth Wheel, Upfitters, Line-X, Moonroof, Clearance Lights, Block Heater, DeeZee Low Profile Tool Box, Roll N Lock.
mmm635 is offline
post #10 of 22 (permalink) Old 02-09-2012, 11:12 PM
09 6.4
webb06's Avatar
radiators are a snap to take out on these trucks as long as you have the tool to get the trans lines out, and sometimes they are a real PITA!!! and make sure you have a drain pain handy cuz the tranny fluid will be all over the floor before you can say OH SHI*!
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
Human Verification
