Replacing the IPR on a 2003 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 (permalink) Old 12-07-2011, 11:23 PM Thread Starter
jweeezy350's Avatar
I am going to be replacing the IPR in my 2003 6.0. Is it possible to do it from underneath the truck like the ICP? I know it is 1 3/8", can you get it with a wrench or will a special socket be needed. Any advise will be appreciated.
Thanks,
Wesley
2003 F-350 Lariat CC/SWB/DRW 6.0
jweeezy350 is offline
post #2 of 25 (permalink) Old 12-07-2011, 11:32 PM
Sponsor
04stroker's Avatar
Re: Replacing the IPR on a 2003 6.0
You can get it with a wrench but not sure if you can get it from the back. It'd be difficult.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #3 of 25 (permalink) Old 12-08-2011, 01:30 AM
I have done it from underneath on an 03. I made a special wrench. Its tough, but it is possible.
ATGF79 likes this.
protraxrptr17 is offline
post #4 of 25 (permalink) Old 12-08-2011, 02:12 AM
Diesel Sled Head
zx800x's Avatar
I do them all underneath on 03's I have them down to 45 min start to finish. 10mm,13mm to remove the shield. Take an 1 1/6 wrench cut it to about 4-5 inches total length,put a notch in the end for prybar. Put the wrench on ,put the prybar on the notch and give it a tap. Then reach up and thread out.
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
post #5 of 25 (permalink) Old 12-08-2011, 02:51 AM
we need pics for that one!
03 Excursion, Banks turbo back, K&N intake, SCT sf2, Scangauge 2, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #6 of 25 (permalink) Old 12-08-2011, 02:59 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
from the top in about 25 minutes
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #7 of 25 (permalink) Old 12-08-2011, 03:32 AM
09 6.4
webb06's Avatar
iv got a special socket and go from the top, also need a wobble and a few 6" extensions...maybe 30-35 minutes swapped. if you've never had to do this then you better at least double the time it will take you. its not a fun one to replace...
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #8 of 25 (permalink) Old 12-08-2011, 04:50 AM
nrook's Avatar
i did mine from the top just like webb06 said and i got the socket from napa, i pulled the ficm for added room and it wasnt to bad at all i didnt think. good luck man
nrook is offline
post #9 of 25 (permalink) Old 12-08-2011, 11:48 AM
Hood Rich
CTC DEEZUL's Avatar
move degas bottle out of way, you dont have to drain it, just fold it over. remove ficm, remove last stud on take that has injector hasnress ground. unplug both ICP and IPR, slide IPR socket down, slide universal down, attatch 12 inch extenstion, than a long ratchet to break free. Also, unplug last two injectors and move harness forward
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #10 of 25 (permalink) Old 12-08-2011, 12:32 PM
Diesel Sled Head
zx800x's Avatar
My bad I was talking about the 03 ICP sensor not the IPR. Yes the IPR from the top as stated remove the FICM.
zx800x is offline
Human Verification
