After EGR, Low Boost? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 12-04-2011, 01:21 AM Thread Starter
Bandwagon Jumper
19_A_LT's Avatar
Got my truck back from my shop after doing my full EGR delete and it seems like it is running lower boost and missing a few horses than before. Is this normal? They rechecked all the boots and clamps. The EGR is still in and plugged in, but the uppipe was changed and cooler deleted? No codes/lights. What else could cause this?
1999 Dodge 2500 ECLB 24V Cummins, 2wd AT, 115k miles. 4" Straight, AFE Dry Filter *For Sale*
19_A_LT is offline
post #2 of 18 (permalink) Old 12-04-2011, 07:11 PM
Administrator
Zmann's Avatar
Re: After EGR, Low Boost?
? check the VGT connector on the turbo but I would think youd code for low boost?
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #3 of 18 (permalink) Old 12-06-2011, 10:16 AM Thread Starter
Bandwagon Jumper
19_A_LT's Avatar
The connector is good and working. The shop even repaired part of the wiring harness going to it. Before the EGR delete, it would make upwards and sometimes over 20psi boost. Now i can hardly get it over 10 pounds when i put the skinny pedal down. My 03 did the same sorta, but i blamed it on not putting the new uppipe in. I am stumped on this new one though.
19_A_LT is offline
post #4 of 18 (permalink) Old 12-07-2011, 07:32 PM
mcdaniel1991's Avatar
what brand Delete did you use? i just finished deleting my 06 and i used sinisters kit it was a pain in the A@# but i think im getting higher boost then before!?
2006 F-250 XLT FX4 PSD 180,000 Mi
Leveled, Innovative and Gearhead tunes, BPD 58v 6 Phase FICM, Straight exhaust, Sinister EGR/COOLER delete, Sinister Coolant Filter, Mobile 1 5w 30, Zoodad
mcdaniel1991 is offline
post #5 of 18 (permalink) Old 12-13-2011, 02:41 AM Thread Starter
Bandwagon Jumper
19_A_LT's Avatar
I used custom diesels kit. It has the block off plate as well as the uppipe.. Is it common for the Turbos to gum up while performing deletes?
19_A_LT is offline
post #6 of 18 (permalink) Old 12-13-2011, 02:49 AM
Gambled and Lost 6.oh
ksieckmann's Avatar
If your only getting 10psi surely you would get a low boost cel
'05 CCSB FX4
Deleted, Studded, SCT w/ Vivian's Looney Wild, Warrens 190cc. DieselRX
ksieckmann is offline
post #7 of 18 (permalink) Old 12-13-2011, 02:53 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
recheck y pipe connection at turbo...
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #8 of 18 (permalink) Old 12-13-2011, 03:53 AM
20 PSI prior to the delete still seems a little on the low side to me. I am not tuned and will see 29 to 30 PSI at WOT.
2003 Super Duty 6.0L 4x4 SC/SB. Coolant filter, exhaust, gauges, CTS with some other stuff
Pulling a 35' KZ Sportster toy hauler
08 KTM450XCW-R
2000 CR500AF
1990 CR500
maps is offline
post #9 of 18 (permalink) Old 12-13-2011, 07:34 AM
matt
mgeistman's Avatar
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #10 of 18 (permalink) Old 12-13-2011, 12:24 PM Thread Starter
Bandwagon Jumper
19_A_LT's Avatar
I don't hit WOT very often; I baby the hell outta it. I know it definately is a dog after the EGR Delete. I also threw a Low Boost Code.
19_A_LT is offline
Human Verification
