In need of serious help no low oil pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 08-06-2011, 11:30 PM Thread Starter
Ok so I have an 03 F350 6.0l It stopped running the other day I have checked oil pressure and I have no low oil pressure so my buddy who works on them for a living tol dme to check the pickup tube in case it fell off so i pulled the oil pan all is well so he told me to check the low pressure oil pump did that looks fine now im at a dead end he doesnt know and the ford dealership doesnt know whats wrong so I am asking if anyone has any idea or come across the same thing also anyone seen the windage try crack or the gasket behind the front plate break where the main oil passage is please help I need this truck up and running. Thanks
Stokedstroke is offline
post #2 of 34 (permalink) Old 08-07-2011, 01:48 AM
Re: In need of serious help no low oil pressure
I assume your truck is not starting?
Mark
bismic1 is offline
post #3 of 34 (permalink) Old 08-07-2011, 02:12 AM
Sarcastic Bastard
When my HPOP let go, it seemed as though I couldn't get Low Pres oil. It wouldn't show on my guage. Try it, maybe it is the problem.
Thanks Eric!
Thanks Doug!
Special thanks to Rich for helping me pick chargers for my newest mod!!
Cobra 19 & 54 is offline
post #4 of 34 (permalink) Old 08-07-2011, 06:26 AM
lubeowner's Avatar
Your hpop took a crap and needs replaced.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #5 of 34 (permalink) Old 08-07-2011, 08:36 PM Thread Starter
Ok guys your saying hpop but I have no oil to feed my hpop my oil filter housing is empty all the time even after cranking for 30 seconds
post #6 of 34 (permalink) Old 08-07-2011, 08:49 PM
it's an 02 05 08
turbodiesel_02's Avatar
most likely its your hpop.id pull the low pressure oil regulat or out and inspect it first.it should not shoot out,if it does the the regulator is stuck and lpo is bypassing.
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #7 of 34 (permalink) Old 08-08-2011, 08:45 PM
DBM
DBM's Avatar
Do you have the correct oil filter and cap on, if not it may not be holding the drainback valve closed
2004 CC 6.0 4x4 lariat
MODS: BPD Oil Cooler, MTW Stage 1 Billet, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/Looney, 4" straight pipe 6k HID's, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
post #8 of 34 (permalink) Old 08-08-2011, 10:48 PM Thread Starter
i changed the oil filter a week before it stopped running so it ran for a week with the new filter i have checked the relief valve its fine. Ok heres the thing u guys say hpop but no one has given me prrof that it is my hpop im not pulling any oil out of the oil pan up into the filter housing to feed the hpop so if someone can explain why my hpop would cause that issue ill replace it
post #9 of 34 (permalink) Old 08-09-2011, 12:02 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
did you find a marble sized ball bearing in your pan???
because thats going to be your problem..... It fell out of HPOP
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #10 of 34 (permalink) Old 08-09-2011, 02:53 AM Thread Starter
No i did not find anything in the pan
Human Verification
