6.0 blowing out white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-12-2011, 04:07 AM Thread Starter
PSN local
SouthJerseyStroker's Avatar
my dad has a 6.0 and this morning going to work it was pouring out white smoke from the exhaust so bad it looked like there was fog outside. finally settled down a bit but kept doing it all day. head gaskets?? or possibly a stuck injector or something?
whats do you guys think?? i own a 7.3 and im not familar with his 6.0
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
Glowshift gauges- trans temp, boost, egt
SouthJerseyStroker is offline
post #2 of 9 (permalink) Old 05-12-2011, 04:47 AM
Dead dinosaur consumer
bigdaddy60's Avatar
Re: 6.0 blowing out white smoke
Probably a blown egr cooler. Egr delete time
bigdaddy60 is offline
post #3 of 9 (permalink) Old 05-12-2011, 06:05 AM
harley master
hawgdoctor's Avatar
get that egr cooler off there before it takes the headgaskets with it. Don't forget the oil cooler too.
06 ccsb-gone but not forgotten
00 rclb-a little of this and that....
hawgdoctor is offline
post #4 of 9 (permalink) Old 05-12-2011, 07:53 AM
What does the smoke smell like?
Are you losing coolant leve in your degas bottle?
Mark
bismic1 is offline
post #5 of 9 (permalink) Old 05-13-2011, 05:18 AM
burning mine saving yours
RocknRoll's Avatar
This.
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
RocknRoll is offline
post #6 of 9 (permalink) Old 05-13-2011, 05:53 AM
A failed injector can look the same way. Hopefully the OP has figured out his issue - whatever it is .....
Mark
bismic1 is offline
post #7 of 9 (permalink) Old 05-13-2011, 07:27 AM
Make sure its smoke... a blown egr will blow steam out of the exhaust and it will look like white smoke. If he's losing coolant that's probably the culprit.
ftb28 is offline
post #8 of 9 (permalink) Old 05-13-2011, 08:55 AM
Sequential6.4L's Avatar
Egr cooler or injector..smell the exhaust and injector will smell strongly of fuel
2008 Ford F250 6.4 PSD. Spartan 350, 5inch Flo-pro, downpipe, AFE stage 2, Intercooler pipe, ZEX nitrous, TS-MP8, Elite wastegate/EGR delete, ARP studs, CFM plenum, pro comp trac bars, Airdog 150, ATS 5-star, Mag-Hytec pans, Readylift, 35's, Road Armor front, Fab four rear bumper.
Sequential6.4L is offline
post #9 of 9 (permalink) Old 05-16-2011, 04:34 AM Thread Starter
PSN local
egr cooler thanks guys. gettin that deleted!
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
Human Verification
