water in fuel sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-02-2011, 06:08 PM Thread Starter
CLAC's Avatar
Are the water in fuel sensors known to be faulty and cause the water in fuel light to come on alot? I'm not due for another fuel filter change yet. Every time I drain the fuel I get a little crud but no water. Would cleaning the plug help? I think I will clean the plug and see what happens. I guess I will go ahead and do another fuel filter change too soon.
CLAC is offline
post #2 of 9 (permalink) Old 05-02-2011, 06:10 PM
Administrator
Zmann's Avatar
Re: water in fuel sensor
i would clean it also
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #3 of 9 (permalink) Old 05-02-2011, 06:34 PM
Administrator
Zmann's Avatar
this may help ?
HFCM and Fuel Pump ? - Ford Truck Enthusiasts Forums
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 9 (permalink) Old 05-02-2011, 06:52 PM
amdriven2liv's Avatar
Great thread for reading ^^^^^^^^^
Thanks Zmann
"I'm hitting easy street on mud tires"
amdriven2liv is offline
post #5 of 9 (permalink) Old 05-02-2011, 07:05 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
This is just copied and pasted from a post I made before so might seem a little off but should give you the full break down on cleaning out the pump. If you wanted I am sure you could do this with the pump on the truck too and skip over disconnecting the fuel lines but here is what I did...
Originally Posted by jdc753 View Post
Sounds like your well on your way, I'll just toss up some pics for ya before you dive into the project.
While your getting that 36mm socket for the fuel filter grab a set of fual/ac line quick disconnects, something like this,
Once you get the filter out and drained undo the 2 lines on the left of the pump (I believe they have some clips, just pull them up and the lines come off) then undo the other 2 lines on the right side (here is where you need to disconnect tools) then undo the 2 wiring harness connectors and finally remove the pump from the frame rail by removing the 4 bolts on the outside of the frame (12mm I think?) Make sure you got a bucket of some sort for collecting the fuel from the filter and lines and more that will come out when you can tip the pump to pull it out.
Here are some pics from when I pulled mine apart for the same reason your describing.
All apart, notice the red gunk at the bottom, this is where the WIF sensor resides and what seemed to keep mine on.
Other side, showing the cover and more gunk around the drain plug. With mine the drain plug was seized to the cover. WIF sensor is the black on on the left.
One more thing you might want to check out sometime is the updated drain plug. It sounds like yours is still easy to remove but they are known to seize to the aluminum housing, and then stip out when you try and remove them. Ended up having to drill mine out.
Here is the updated plug that is beefier, can put vise grips on it if the 6mm allen plug strips, and it helps in wicking the fuel/water out of the housing so as to not make soo much of a mess.
I believe these are the appropriate Ford/International Part numbers:
Diesel Technician Society
Ford: 6E7Z-9C082-A
International: 2589259C91
If those numbers don't work, ask to see if they can get the HFCM drain plug from an LCF truck.
Or some aftermarket vendors also carry the plug,
Diesel Part # SB6E7Z9C082A - HFCM Water Separator Drain Plug Upgrade - Diesel Performance Parts
Best of luck and hope you can get back to running good without too much time or money.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #6 of 9 (permalink) Old 05-02-2011, 07:13 PM Thread Starter
CLAC's Avatar
Yeah most likely that is what I'll have to do is pull it apart and clean it. This started a few weeks back right after I put a bottle of Marvel Mystery oil in the tank and it broke a bunch of crud loose.
One question is there a gasket between the cover and fuel filter housing or just use appropriate RTV gasket sealant?
CLAC is offline
post #7 of 9 (permalink) Old 05-02-2011, 07:32 PM
Administrator
Zmann's Avatar
sweet that was actually the thread I was looking for to link to !!
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 9 (permalink) Old 05-02-2011, 07:33 PM
Administrator
Zmann's Avatar
it's a gasket you can see it in the pic
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 9 (permalink) Old 05-02-2011, 07:51 PM
6Leaker
jdc753's Avatar
It's a little o-ring like gasket. Best to simply leave it alone as much as possible (unless of course its already brittle and cracked and/or not sealing) and you should be able to reuse it like I did.
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/10-6-0l-power-stroke-technical-info/102055-water-fuel-sensor.html
Posted By For Type Date
Water in fuel light. - Ford Truck Enthusiasts Forums This thread Refback 11-06-2015 01:34 PM
Water in fuel warning light stays on, and a good 6.0 mechanic in Tucson? - Ford Powerstroke Diesel Forum This thread Refback 10-30-2015 03:42 AM
